1. Tractor-trailer
    Tractor-trailer Bobtail Member
    14
    6
    Nov 30, 2018
    I have a detroit12.7 egr engine that was deleted and tuned to 550hp with 1850 torque non wastegate turbo(borg warner171702)truck doesn't have goodpower when going through gears sluggish 9/10 gear falls flat hit a small hill or incline it falls back can't accelerate pedal goes to floor and does nothing until I crest the hill, runs ok on flat ground all of that with truck bobtail, empty or loaded,I changed injectors from stock 7860 to 5915 to flow more fuel but didn't make a difference the guy that changed them out said he set all them to .75 Don't know if that's right need help!!!!
    Badmon Thanks this.
  3. nikmirbre
    nikmirbre Road Train Member
    5,584
    10,335
    Jul 27, 2011
    High Point NC
    Is the actuator still there?
  4. Tractor-trailer
    14
    6
    Nov 30, 2018
    Which actuator? I deleted the egr system completely
  5. Tractor-trailer
    14
    6
    Nov 30, 2018
    Which actuator I deleted the egr system completely
    nikmirbre Thanks this.
  6. nikmirbre
    5,584
    10,335
    Jul 27, 2011
    High Point NC
    I had a Detroit 60 series deleted also but the turbo actuator was still there but had to be turned a certain way.....
  7. AModelCat
    164,436
    How much boost it makes would be a good starting point.
    lester and blairandgretchen Thank this.
  8. Tractor-trailer
    14
    6
    Nov 30, 2018
    25-28psi 30 if I push it
  9. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    CK. the T P S under fuel ped. it may not be working at full blast?
    blairandgretchen Thanks this.
  10. Tractor-trailer
    14
    6
    Nov 30, 2018
    Maybe but I put a new pedal assembly with sensor on it but a tech said the wires were wrong so he rewired it because it wasn't getting the 100%value when depress on the laptop
    baha and blairandgretchen Thank this.
  11. Tractor-trailer
    14
    6
    Nov 30, 2018
    I have a non wastegate turbo so there's no actuator
