Low pressure Regen
Discussion in 'Freightliner Forum' started by Metrysha, Aug 18, 2019.
  1. Metrysha
    Metrysha Bobtail Member
    20
    Sep 7, 2018
    guys! Hello! what options? what do you think?
  3. Brandt
    Brandt Road Train Member
    4,625
    6,359
    Sep 17, 2012
    Not sure what even going on. Is some one putting high RPM on foot pedal think he doing something ? The computers will do a parked Regen if needed or asked for a parked regen
  4. Metrysha
    20
    Sep 7, 2018
    Yes, I was sleeping when it happened. o_O This video just did. and no, nobody presses the gas pedal. )))
  5. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    low pressure regen :)
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    So if it was idling when it started a regen, just means that Auto Elevate feature is set so it does a regen automatically when parked.
    Just leave it alone, should go back to normal in 20 or 30 minutes.
    mhyn Thanks this.
  7. Metrysha
    20
    Sep 7, 2018
    well. no idea why is no pressure. I’ll go to the service.
  8. Brandt
    4,625
    6,359
    Sep 17, 2012
    It's the Auto Elevate. That's what the new trucks do. My 2017 truck would do it every 6 hours of parked idle time. My 2020 does it, I have not timed it yet to see if it still every 6 hours.
    I had a 2011 truck and you would wake up in the morning and the Regen light would be on. It could not do automatic Regen. So they fixed that, now the computers do it. You probably never to manual regen. I think the computers do it sooner because now it only takes 20 minutes. A manual Regen used to take like 45 minutes. It's probably better on the DPF to just do it every 6 hours of idling vs waiting till the drives wakes up and doing it manual.
  9. Metrysha
    20
    Sep 7, 2018
    3 psi?! Really?! Normally 15-20 ! I have 3 psi!!!
    I’m not idiot. I know about Regen and I know my truck!
  10. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    nobody says you are an idiot. you don't know how system works. go to service and pay them if you want ))) ...
    there is nothing wrong here. You will see high boost when doc inlet and dpf outlet pressure difference is high... Like people mentioned above it's Auto Elevate feature kicked in. do you know what is Auto Elevate ?
    Working2party Thanks this.
