low rpm miss
Discussion in 'Freightliner Forum' started by jim3029, May 3, 2015.
  1. jim3029
    jim3029 Bobtail Member
    38
    11
    May 27, 2012
    Janesville,WI
    I have a 2013 Columbia glider with 12.7 Detroit ddec4 with 310000 miles and it will quite often start idling rough and feel rough at low rpms in the lower gears. Once the rpms come up it seems to smooth out and I really don't notice it. I had my mechanic ride with me and do a injector cut out test. It passed the first time then failed then passed then failed again but each time it failed it showed different results so he could not isolate the problem. He said it needs to get worse so he can tell what injector to replace if that's in fact what it is. So far it's not getting worse but is just enough to be very aggravating. Has anyone had this problem before? Would it be a good idea to pull the ecm off when I go on vacation and send it to Pittsburg Power and have them test it out?
  3. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    If I were going to send it, I would send it anywhere other than PP due to the recent blowup of that KR truck.
    I don't know anything about this shop but it may be worth a phone call... http://oldtunerguy.com/home.php
  4. maggard359
    maggard359 Medium Load Member
    476
    413
    Nov 20, 2013
    Florida
    You need a new mechanic, the injector cutout would have told you which cylinder. I would find cylinder move injector and see if it follows to new cylinder before doing anything else. If it follows it is injector if not then it will be wiring or doubtful but possible ecm problem.
    magoo68 Thanks this.
  5. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    X2 on possible ECM issue a lot of 12.7's developed that miss which really didn't affect power or fuel economy much .. Something to do with low voltage or ECM battery getting weak is what they suspected... Best bet is to hang a known good ECM on it and test drive then you narrow down possibilities PS I drove one with that miss for 3 yrs till I switched trucks wasn't affecting much just annoying was all
  6. EHB
    EHB Medium Load Member
    491
    209
    Apr 26, 2011
    Newfoundland
    Yes most trucks have electronic and electrical problem but you still have to back to basics.
    If it is hesitation is at the start I would look at a pressure problem on the pump and maybe a line or exhaust or air intake system may be restricted in some way.
    Check all filters and fuel pressure.
    If you muffler has not been replaced in a while I would suspect it could starting to plug up.
  7. jim3029
    38
    11
    May 27, 2012
    Janesville,WI
    Thanks guys. These are all great answers and gives me several things to try. I just ran 700 miles, 16000# up and empty on the way back and got 7.7 mpg so I really can't say it's running terrible but it just never used to do this and it is annoying. Thanks again for taking the time to help.
  8. jim3029
    38
    11
    May 27, 2012
    Janesville,WI
    Just drove truck back from the shop and it ran great. Apparently oil seeped down the wiring harness for the injectors and into the connector. They replaced the wiring the harness and that seemed to solve the problem.
  9. truckerbangin
    truckerbangin Light Load Member
    268
    45
    Jan 22, 2013
    i'd try swapping in a new injector harness and see if problem persist
  10. Dave_in_AZ
    425,930
    Sounds like what is diagnosed what the machine calls " bad fuel injector rail ". Sounds like they fixed exactly what the issue was. I had a similar problem with a century once. Waited for 3 days until they could get to it, and dude had it fixed in about 15 minutes.
