Low weight roads.
Discussion in 'Experienced Truckers' Advice' started by Speedemon1084, Sep 4, 2014.
  1. Speedemon1084
    Speedemon1084 Medium Load Member
    381
    169
    Dec 24, 2011
    Collins, MS
    Anybody know where I can find a listing of the low weight roads in MS?
  3. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
  4. kemosabi49
    11,017
    48,119
    Jan 13, 2013
    SW Arkansas
    If you have a Rand Mcnally truckers atlas, there is a section in the front that list restricted highways in each state.
    ncmickey Thanks this.
  5. STexan
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    States are changing bridge and road restrictions every year and a new atlas will be using 2 year old data [that could be found]. An atlas can be "helpful" in some cases but generally are useless today with a lot of new inspections and [de-rates] being done monthly, along with rapidly changing federal/state minimum specifications.
    Cetane+ and NavigatorWife Thank this.
  6. Speedemon1084
    381
    169
    Dec 24, 2011
    Collins, MS
    All it tells is restricted roads. Some roads trucks are allowed as long as they are under a certain weight.
  7. snowwy
    snowwy Road Train Member
    20,618
    13,340
    Jul 6, 2009
    funny how people always say the atlas. which only lists state highways and roads.
    like Texan says. towns and counties change their roads often.
    take the town in west virginia. in 90 days they will be shutting off THROUGH trucks. unless your making a local delivery. you'll soon have to go around.
    if the atlas had every road in the country listed. we'd be packing bibles instead of an atlas.
    NavigatorWife, davenjeip and Cetane+ Thank this.
  8. Lepton1
    Lepton1 Road Train Member
    12,647
    25,593
    Nov 23, 2012
    Yukon, OK
    Amen.
    Ran in and out of Toledo, OR last week. Highway 101 in the 2014 Atlas shows you can access it coming in from the south, but my dispatch information and the customer both advised that was now closed to big rigs.
    When in doubt call the customer, they may have routing information, or call the state information line.
    If you are running with a trucker specific GPS then make sure you have the latest update, it might have the information about load restricted roads in the database and route you correctly. However, always use the GPS with a pound of salt.
  9. davenjeip
    davenjeip Medium Load Member
    459
    257
    Dec 20, 2009
    Port Charlotte, Fl
    That's a great point. Atlas is a great tool, but doesn't tell you everything.
    I used to run a lot of small towns in the northeast. Couldn't count the number of times I came across a low bridge or a road I wasn't legal to be on due to weight, or some other reason. I always checked my atlas before a trip, but still found a lot that weren't listed.
    NavigatorWife Thanks this.
  10. wore out
    wore out Numbered Classic
    17,551
    219,382
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Other than a sign near the junction of a road there is no tell all accurate tool. Most signs just designate weight not clearance issues several miles down the road. I realize the signs do no good for trip planning but that's why we must be versatile.
    davenjeip Thanks this.
  11. tracyq144
    tracyq144 Heavy Load Member
    884
    546
    Feb 15, 2009
    MN
    Yeah, I love it when I am tooling down a supposedly legal road, and come up on a weight restricted section or bridge. No place to turn around. What I do is put all my body weight on my legs (get up off the seat, in other words), cross my fingers, and hammer down.
    Whatugonnado? :biggrin_25521:
