Ltl single trailer
Discussion in 'LTL and Local Delivery Trucking Forum' started by Ddr1992 579, Jul 21, 2019.
  1. Ddr1992 579
    Ddr1992 579 Medium Load Member
    395
    100
    Sep 10, 2018
    Can you apply to an ltl company like conway freight or yrc that pulls double and triples with only a class a cdl and no triple or double endorsements? Don't want to pull doubles or triples and I like the idea of a city tractor pulling a 28' pup...
  3. jmz
    jmz Road Train Member
    1,218
    2,883
    Mar 9, 2018
    Great Plains
  4. Ddr1992 579
    395
    100
    Sep 10, 2018
    Is there any companies that only run 28ft pup trailers w/ or w/o liftgate/ramp? If so could u tell me the names?
  5. Ffx95
    Ffx95 Road Train Member
    1,370
    2,635
    May 18, 2017
    There will be times when you’re only rolling with a single pup but for most ltl companies like YRC they’ll want you to get the doubles triples endorsements.
    Texas_hwy_287 Thanks this.
  6. Pharroh336
    Pharroh336 Light Load Member
    154
    106
    Apr 4, 2013
    Parts Unknown
    Sysvo, Us Foods, PFG, Gordon Food Service, Reinhart Foods, Mondelez Global (Nabisco)
    Mike2633 and stwik Thank this.
  7. MACK E-6
    50,128
    239,286
    That’s really an easy test too, even if you never do it.
  8. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    NO, you sign on with an LTL company you haul what you are assigned, and you'll need your double-triples,tankers endorsements as well as hazmat...
    they all run a variety of trailers of all lenghts and with lift gates and with out.
    FlaSwampRat Thanks this.
  9. haz-matguru
    haz-matguru Road Train Member
    2,933
    4,539
    Feb 18, 2012
    Most LTL companies use 35ft -57ft Van's for local work. And a set of pups for line haul. At times a single pup may be the only trailer on a line run. Or a pup may be sent out for local P&D. It changes from day to day. A local driver may be sent out with a set also. You would leave the rear pup at customer lot. Then make deliveries wit the 1st. And return to grab the 2nd one to make drops then start picking up inbound freight. And return to drop it and gather freight with the next pup. Normally this is done for runs further away from the yard. Like 100- 150 miles away. It's a different set up everyday for local or line haul. So therefore the criteria for a driver is to have tanker, hazmat, and doubles endorsements. Some may give a grace period to obtain the endorsements after hire date.
    Texas_hwy_287 and FlaSwampRat Thank this.
  10. okiedokie
    okiedokie Road Train Member
    14,008
    111,369
    Jun 13, 2011
    PNWET
    I drove line over the Cascades for 8 years. The worst was a 102 pup for the front box and 2 regular trailers behind it. A few times I'd have trailers from every ltl company on the West coast at once. Wasn't sure who I worked for. Crazy combos, box,tank,flat at once.
  11. EuropeanTrucker
    EuropeanTrucker Medium Load Member
    564
    875
    Jun 15, 2018
    Why do some LTL companies require tanker endorsement?
