Lugnuts not tightened on rear duals
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Double Dawg Dare, Nov 16, 2019.
  1. Double Dawg Dare
    Double Dawg Dare Bobtail Member
    8
    15
    Dec 3, 2005
    Minnesota
    has anyone ever had this happen to you? I want to go after the shop that did this but I need a bit of proof as to what it looks like from others that have experienced it. I have photos.
    truckdriver31 Thanks this.
  3. shogun
    shogun Road Train Member
    6,075
    72,164
    Jan 23, 2009
    Doing a regen
    Most shops nowadays cover themselves liability wise saying that you must stop and recheck the torque within 50 miles. How soon did the wheel come loose? I always watch them impact them on and verify they use a torque multiplier then visually check to make sure they all have them equally tightened by thread depth.
    I have never had to go after a shop for it though. I think there might be other similar posts on here if you use the search function at the top right.
  4. Doealex
    Doealex Medium Load Member
    597
    1,132
    Feb 21, 2018
    This is one of my greatest fears - driving down the freeway and one of the tires flying and hitting someone.
    Rideandrepair and truckdriver31 Thank this.
  5. 201
    201 Road Train Member
    12,854
    26,458
    Apr 16, 2014
    high plains colorado
    Why, what's the hub-bub, bub, you lose a set? Years ago when we had wagon wheels, it was the drivers responsibility to check your lugs every couple days. Sometimes, you'd get a half a turn.
    baha, Rideandrepair, okiedokie and 3 others Thank this.
  6. Double Dawg Dare
    8
    15
    Dec 3, 2005
    Minnesota
    This was the inside rear and I did not watch him. It carved a circle out of the wheel then shattered it. In that process it rubbed against the out side wheel and carved into it before all of it busted. There was a slight shake to the truck but we were looking at the front end for the problem. I drove it for approx 2 weeks before the shaking came about
  7. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    you are suppose to pretrip the tires before you drive.
  8. Double Dawg Dare
    8
    15
    Dec 3, 2005
    Minnesota
    Every evening. You could not see the problem. Outside nuts were always good
  9. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    so you got bud wheels
    Rideandrepair and Dave_in_AZ Thank this.
  10. 201
    12,854
    26,458
    Apr 16, 2014
    IDK, something doesn't sound right for loose lugs. If they were loose, you'd think the outside would come apart 1st, or wobble. Maybe the inside rim came apart, I've seen that happen with Budds.
  11. Brandt
    Brandt Road Train Member
    4,641
    6,394
    Sep 17, 2012
    I don't see how you can go after shop if it's been two weeks. The pre trip thing will kinda mess up you claim. They do make things you put on lug nuts that show when they are loose.
