M11 coolant system problems.
Discussion in 'International Forum' started by LyleOdom, May 29, 2014.
  1. 75W900A
    75W900A Bobtail Member
    7
    5
    May 30, 2014
    Yeah, I would just go with a reman, it's not as bad of a job as it looks.
    ESN is engine serial number, it's and 8 digit number on the dataplate
    LyleOdom Thanks this.
  3. LyleOdom
    LyleOdom Bobtail Member
    10
    May 29, 2014
    Collins, GA
    He was wanting me to switch them out to make sure that was the problem before I bought the wrong part.. I'm just gonna take the whole thing off.
    ESN:34780798
    where is the best place to get a reman?
  4. rank
    rank Road Train Member
    9,919
    113,509
    Feb 11, 2010
    I looked at buying a International 9800 cabover a couple of years ago. Pretty Sure it was a '99 and pretty sure it said ISM on the top cover too. FWIW, I have a 1998 KW and it says M11. Carry on gentlemen.
  5. 75W900A
    7
    5
    May 30, 2014
    It's an M11 350 with CPL 1856 built in Jamestown New York on June 8 1995
    anyway... I don't know where you are located, but a good heavy duty fleet parts store will carry a good reman. It calls for a CP2040 which is a holset brand compressor cummins has used for 20+ years. Any truck dealer can get it as well as cummins if you have a local distributor.
    hope this helps
  6. LyleOdom
    10
    May 29, 2014
    Collins, GA
    I got a reman Saturday.. It was $289 which I didn't think was to bad.. Core was over $500 though.. Thought that was kind of steep.. So I'll definitely be bringing the core back ASAP! I've almost got the air compressor off. There's one bolt that's an inch from the frame that I had to borrow a short 5/8 wrench from my neighbor just so I could get to it. I've got it lose but now I can't get the wrench back on it.. Is there some kind of special tool I need? A socket will fit on it but not with the handle so that's pretty much useless..
  7. LyleOdom
    10
    May 29, 2014
    Collins, GA
    finally got the reman on there. It runs great. thanks for the help everyone! I definitely learned a lot over the past couple days!
    Heavyd Thanks this.
  8. 75W900A
    7
    5
    May 30, 2014
    Glad you got it. What did you do about the bolt?
  9. LyleOdom
    10
    May 29, 2014
    Collins, GA
    I bought a set of tools that look like the open end of a wrench that fit on the socket handle
