Mack Anthem door locks
Discussion in 'Mack Forum' started by 86scotty, May 1, 2026.
  1. 86scotty
    86scotty Road Train Member
    4,769
    13,094
    Aug 27, 2017
    Appalachia
    Bought a 19 last week. I love the truck but I've got some door lock issues. Mostly I need to know how they are supposed to work.
    Here's my issue. First, I know my passenger door actuator is out. For whatever reason Mack didn't put a manual door lock on these doors from the inside of the door so I can only lock that door with the key from the outside and get in on the driver's side and lock it (at nighttime). I'll be fixing this of course.
    Second, sometimes when I'm in the truck and yank up on the driver's door handle it will not open the door, even if I didn't lock the doors with the switch when I got in. I have to unlock with the switch to open the door even if I never locked it.
    Sometimes I can yank up really hard on the door handle from the inside and it will open the door, whether I locked it or not, and sometimes it won't no matter how hard and fast I yank up on the handle.
    Also, I have gotten out of the truck and while fueling a couple of times WITHOUT locking a door (key in ignition, never touch lock switch) and it will lock me out. Luckily I had a spare key both times.
    So, how are these doors locks SUPPOSED to work?
    I hope to add keyless entry and the modules are cheap used but not sure where the module even goes or what it would take to program it. Fobs are cheap too.
    D.Tibbitt and Grumppy Thank this.
  3. Grumppy
    3,271
    11,629
    Dec 11, 2010
    West Monroe, La
    And there's a Mack engineer somewhere doing the Mutley sinigger at you......
  4. 062
    062 Road Train Member
    6,365
    34,093
    Oct 20, 2013
    Could be binding up from lack of lube or one of the little plastic pieces is damaged or popped off the rod.
    You’ll have to pull the door panel and see. I prefer using stuff called “lock-ease” for lube. You won’t have to oil it again for years.
  5. tscottme
    tscottme Road Train Member
    If pulling hard on the handle works, I suspect the mechanism is binding. Also, pulling hard will eventually cause it to fail, at the worst time usually.
  6. Judge
    93,451
    Yeah. I don’t have any issues with door locks. Gotta be something sticking, it’s electric push button not manual locks as you say, but door opens from inside locked or not. I keep keys in my pocket though, always have.
    Speedy356 and 86scotty Thank this.
  7. 86scotty
    4,769
    13,094
    Aug 27, 2017
    Appalachia
    Me too. Always one in the ignition, separate one in pocket. Remove ignition key if I'm someplace unsafe but I usually just lock the doors with the ignition key in it.
  8. OldeSkool
    OldeSkool Road Train Member
    2,123
    6,946
    Jul 17, 2018
    New Hampshire
    Western Star has a really cool feature. They’re electric locks, but you have to manually lock the drivers door with a key when you get out, or use a key fob. I got locked out of my Freightliners numerous times from accidently bumping down the lock as I was getting out of the truck. It’s nice not to have to worry about that anymore.
