Mack CXU613 P0500 code
Discussion in 'Mack Forum' started by habfleet, Jun 14, 2021.
  1. habfleet
    habfleet Light Load Member
    163
    23
    Feb 5, 2012
    elwood nj
    I have replaced te speed sensor the dealer replaced the speed sensor harness . Fault code keeps coming back . All this started after dealer put in new transmission . Any ideas . 2013 CXU613 Vin# 048577
    Thanks
  3. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    If this is an MDrive transmission it is quite possible that the tone ring inside the transmission was damaged while the top plate was being installed by the dealer. It is a common mistake (that I have made)
    spsauerland Thanks this.
  4. habfleet
    163
    23
    Feb 5, 2012
    elwood nj
    No it is not a M Drive. Has he eaton transmission in it. I was kind of thinking along the same lines that there may be a problem with the tone ring but when I change the sensor I did feel the tone ring.
