Mack mp8 issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Skooter1969, Sep 1, 2020.
  1. Skooter1969
    Skooter1969 Bobtail Member
    Sep 1, 2020
    7
    Thanks Received:
    Iam working on a 2011 mack cxu613 it has a mp8 and mdrive trans everything is fine when you first take off after about 5 mile truck just has no throttle response engine still running until you come to a complete stop and it dies put in neutral engine starts back up and runs a bit and the same thing happens intil it sets awhile only code are gear selector code any help would be much appreciated thanks in advance
  2. McMahons Trucking
    McMahons Trucking Light Load Member
    Jul 4, 2018
    274
    Thanks Received:
    119
    Sounds like the the clutch isn't disengaging. Does it die if you put it in Neutral before coming to a stop?
  3. Skooter1969
    Sep 1, 2020
    7
    Thanks Received:
    Yes it's costing to a stop but when it stops it dies
  4. vacaflortoro23
    vacaflortoro23 Bobtail Member
    Nov 11, 2020
    8
    Thanks Received:
    Hi, I have a Mack SXU VISION 2014 with motor D13 MP8.
    I have a leak in the exhaust leak with the smell of oil and gasoline
    I have checked the head and the turbo, and both are good
    Does anyone know what else should I check?
    VIDEO WITH LEAK
  5. Terry tj
    Terry tj Bobtail Member
    Apr 26, 2021
    Thanks Received:
    Buddy have you found your problem. I have exactly same thing going on. Please let me know. Tex me. Terry. 780-882-0975. Thanks
  6. Terry tj
    Apr 26, 2021
    Thanks Received:
    Mine same. Spent a ton and still doing same thing.
