Maintaining grease hubs
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Ozdriver, Jan 5, 2022.
  1. Ozdriver
    Ozdriver Heavy Load Member
    770
    1,394
    Oct 16, 2015
    Australia
    How often should you re-pack grease hubs? I run oil hubs on all my trailers, but I fitted new K-Hitch axles on my converter dolly and they have grease hubs. A Google search didn’t come up with much relevant info.
    Cat sdp and Pamela1990 Thank this.
  3. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    I pull them down and inspect and repack along with new seal at every brake job. I believe it is a recommendation of hub mfg’s
    Ozdriver and Pamela1990 Thank this.
  4. Ozdriver
    770
    1,394
    Oct 16, 2015
    Australia
    Problem is my brakes last forever. The dolly has done 330,000 kms (205,000 miles) and the brakes are barely worn. I just took a little play out of the bearings yesterday and I was thinking it’s about time I re-packed the bearings. About one third of the mileage is when there is no load on it when I tow it behind a trailer.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    Sharp truck mister! Does it get good mileage?
    A large fleet I worked for did them at 5 years. Hendrickson standard hub repack and seal schedule is 2 years or 300,000 km. Preset hub schedule is 5 years or 800,00 km.
    Ozdriver and Goodysnap Thank this.
  6. Diesel Dave
    9,712
    33,145
    Jan 20, 2010
    Hesperia, Ca.
    Welcome back @Ozdriver , haven’t seen you here for awhile. Are you still running your KW 3408 Cat ?
    Ozdriver Thanks this.
  7. Cat sdp
    Cat sdp . .
    21,316
    76,304
    Apr 8, 2012
    Orion's Belt
    Welcome back….:)
    How much dirt and flooded areas do you deal with……? I would guess that changes the service interval…..
    I’m an oil hub guy too….
    Ozdriver and Diesel Dave Thank this.
  8. Ozdriver
    770
    1,394
    Oct 16, 2015
    Australia
    Yes, that’s the mileage to service I was more or less thinking.
    With 2 trailers at 79 tonnes about the same fuel mileage as a modern truck as long as you drive it correctly.
    BoxCarKidd Thanks this.
  9. Ozdriver
    770
    1,394
    Oct 16, 2015
    Australia
    Not so much dirt as I used to when I used to go out to drill rigs in the oil boom a few years ago.
    Yes, oil hubs are best imho, as long as bearing pre-loads are correct and you use properly installed quality seals.
  10. Ozdriver
    770
    1,394
    Oct 16, 2015
    Australia
    Yes, still running the V8 and doing what I’ve always done.
    Oxbow and Diesel Dave Thank this.
  11. Diesel Dave
    9,712
    33,145
    Jan 20, 2010
    Hesperia, Ca.
    I was looking for your truck in the series “Outback Truckers”……. Visiting Australia is on my bucket list, just to go for a ride along. I don’t think I would be able to handle driving on the wrong side of the roads ;):eek::rolleyes:
    Ozdriver and Cat sdp Thank this.
