Maintenance schedule on 4300 DT 466
Discussion in 'International Forum' started by DPForumDog, Feb 18, 2019.
  1. DPForumDog
    DPForumDog Bobtail Member
    20
    6
    Nov 13, 2015
    Where can I get a maintenance schedule for a 4300 DT466?
    We may need to replace/rebuild an engine and if we do I want to do a better job of preventing future problems.
    Thanks
    Granny DP
    DPForumDog
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Call local International dealer.
  4. Heavyd
    Heavyd Road Train Member
    7,830
    6,282
    Feb 4, 2009
    Copied and pasted from the manual;
    Daily Check oil level1 Check coolant level1 Drain water separator1 Inspect Charge Air Cooler (CAC)1 Inspect for external leakage1 Inspect air restriction indicator2
    240,000 km (150,000 miles) 2–1/2 years 6,000 hours
    Extended life coolant7
    24,100 km (15,000 miles) 6 months 550 hours
    Change engine oil and filter and secondary filtration filter, if equipped (See CAUTION)3, 8 Inspect belt, air intake piping and clamps Check coolant concentration
    24 months Pressurize induction system1, 4
    48,300 km (30,000 miles) 12 months 1,100 hours
    Change fuel filter and clean strainer5
    290,000 to 322,000 km (180,000 to 200,000 miles) 6,700 to 7,500 hours
    Measure crankcase pressure4 Inspect turbocharger1
    Annually Inspect electrical system1
    500,000 km (300,000 miles) 5 years 6,000 hours
    Service cooling system
    193,100 km (120,000 miles) 5,000 hours
    Inspect vibration damper1, 6 Adjust engine valve lash4, 6 Adjust engine brake lash4, 6
    soultrader Thanks this.
