Make holes chassis for quarter fenders
Discussion in 'Ask An Owner Operator' started by Batman13, Oct 27, 2020.
  1. Batman13
    Batman13 Light Load Member
    110
    45
    May 20, 2020
    What tool do I use to make some quarter fender holes in the chassis?? This freightliner does not have any...need info...I already tried a drill gun..no luck..
  3. Coolbreezin
    Coolbreezin Medium Load Member
    410
    440
    Jun 11, 2016
    Florida
    Its against DOT law to drill or weld on the frames. Those 1/4 fenders are supposed to mount in the holes for yr suspension. But if your bent on making holes, get titanium bits. Slow & easy with pouring cooling water on the tip.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Only the flanges (for drilling). That's the top and bottom "lip". The side is fine.
    §393.201 Frames.
    (a) The frame or chassis of each commercial motor vehicle shall not be cracked, loose, sagging or broken.
    (b) Bolts or brackets securing the cab or the body of the vehicle to the frame must not be loose, broken, or missing.
    (c) The frame rail flanges between the axles shall not be bent, cut or notched, except as specified by the manufacturer.
    (d) Parts and accessories shall not be welded to the frame or chassis of a commercial motor vehicle except in accordance with the vehicle manufacturer's recommendations. Any welded repair of the frame must also be in accordance with the vehicle manufacturer's recommendations.
    (e) No holes shall be drilled in the top or bottom rail flanges, except as specified by the manufacturer.
    p608, Coolbreezin, Bean Jr. and 5 others Thank this.
  5. AModelCat
    165,125
    You can drill the web just fine. If you couldn't, how would you mount anything to the truck for upfitting?
    You can weld a frame too. Just has to be done as per the manufacturer's repair procedure.
    Lonesome, Rideandrepair, 98989 and 5 others Thank this.
  6. Long FLD
    Long FLD Road Train Member
    12,970
    54,421
    Mar 4, 2015
    Buy a Hogebuilt bracket for Airliner suspension.
  7. AModelCat
    165,125
    If you're going to drill a hole, quickest and easiest way is with a mag drill. They aren't cheap but can be rented.
  8. Spyro2112
    Spyro2112 Medium Load Member
    631
    438
    Mar 17, 2018
    Start with a small drill bit and work to large
    Rideandrepair Thanks this.
  9. D.Tibbitt
    157,390
    ezrider has some videos on utube of him using mag drill to cut holes for when he stretched his pete
    Rideandrepair and Bean Jr. Thank this.
  10. abyliks
    abyliks Road Train Member
    4,154
    9,795
    May 2, 2010
    ludlow MA
    Any pics? I find it hard to believe there’s no holes there for any fenders, whether empty or cross member.
    The average person will never be able to tell where a GOOD welder welded a frame
    wis bang and Rideandrepair Thank this.
  11. Coolbreezin
    410
    440
    Jun 11, 2016
    Florida
    Thank you for educating me. Im gonna go drill the crap outta my frame now!:confused:
  12. p608
    p608 Road Train Member
    2,181
    2,993
    Nov 10, 2016
    No it's not.
