Hello was wondering what was all involved in switching the gears in a 9speed to make it an Overdrive by switching the 8th and 9th gear and was wondering if anyone on here has done it and there thoughts thanks in advance
Making a 9speed OD
Discussion in 'International Forum' started by Agtech1206, Aug 11, 2016.
Why not just convert it to a 13 speed.
poppapump1332 Thanks this. -
I've thought about this too I'm looking into finding a 13speed auxiliary box as well
u dont need a 13 speed auxiliary all you need is a couple of valves and a different shift know but you will not make it an overdrive trans. your top gear will still be the same 13 just a little easier to drive on the hills that's about all
Are you talking about making it a double over,with high gear against the dash?
I don't think the newer trans can be flipped. It was the rt and rto that they did that to. -
Yes that's what I'm wanting to do mine is a 1979 RTF 11609 my gears are 433 so would like an Overdrive thanks
You have to have 4th and 5th swapped around. Have to pull the shafts out,have the gears press off and on. Better to take it to someone that knows what they're doing. Not exactly a diy project.
Okay thanks that will be a winter project is it worth doing? Right now I'm around 63 mph at 2200 I'd like to be 70-75 at 2200
I have no idea what the cost would be. You'll have to call around and see. It should be cheaper than swapping rears.
062 is on tract. If you put a 13 spd box on the back of that will give you about 12% overdrive. If you swap the gears in the front of the main box that will give you about 18% OD. Do both for about 30% OD.
There are many different options, transmission models, and ratios which maybe indicated by only a letter like B. RT12609B = 22% OD.
This is all off the top of my head and only meant as an example. The point of my reply is to inform you of this and that if you over gear for your HP and torque you will be shifting all the time. That will defeat your fuel savings and wear you out.
There is a Eaton sight on line that will answer all of those ratio and road speed questions.
The 13 speeds worked really well on lower HP engines because you could shift about every 450 rpm and keep them in their best rpm range.
What engine do you have?
