Manual slide 5th wheel
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Thetrashnoob, Aug 7, 2025.
  1. Thetrashnoob
    Thetrashnoob Light Load Member
    299
    57
    May 30, 2019
    I have a question, something I’ve never had to deal with before. In the past, all the ones I’ve felt with have been air slide.
    How do you slide/move a non air slide 5th wheel?
  3. '88K100
    '88K100 Road Train Member
    1,491
    3,595
    Aug 23, 2020
    Move 5th wheel same as air slide but you have to Manually unlock the 5th wheel to slide then Manually release lock to lock 5th back in place
    Lonwolv54 Thanks this.
  4. Thetrashnoob
    299
    57
    May 30, 2019
    I got more info, it’s a “fixed” 5th wheel. It seems like it’s just sitting a bit farther forward on the front axle then it should be, but not sure how it gets adjusted
  5. Numb
    Numb Crusty Curmudgeon
    4,323
    10,269
    Jan 30, 2012
    Charlotte, N.Carolina
    "fixed" 5th wheel means it's welded in place.
    it ain't movin'
    snowmantrucking101 and Pickleball Thank this.
  6. Deezl Smoke
    Deezl Smoke Medium Load Member
    539
    356
    Feb 12, 2011
    Hillsboro Oregon
    A picture would be worth that thousand words on this one.
    MACK E-6, 201 and Walk Among Us Thank this.
  7. Thetrashnoob
    299
    57
    May 30, 2019
    It’s bolted down, but I was under the impression it’s considered fixed and doesn’t move. Again not used to this setup so I am trying to learn.
    201 and Numb Thank this.
  8. Thetrashnoob
    299
    57
    May 30, 2019
    I’ll have to get a picture, it’s a truck that I’m looking at.
  9. SmallPackage
    5,793
    18,580
    Dec 20, 2019
    Marion Texas
    Tractor was set up with that fifth wheel to pull one trailer or trailers all set up the same way. Lighter weight and less hassle that way.
    Oxbow Thanks this.
  10. Numb
    4,323
    10,269
    Jan 30, 2012
    most tankers I drove had a fixed 5th wheel
  11. Big Road Skateboard
    7,104
    40,326
    May 2, 2021
    It's fixed, it's not moving, you can't adjust it's position without unbolting it, and maybe not even then.
    Oxbow Thanks this.
