Manual transmission issue
Discussion in 'International Forum' started by EastHighwayMike, Jan 26, 2024.
  1. EastHighwayMike
    EastHighwayMike Bobtail Member
    I have a 1999 International 4900. 5th and 6th gear truck shakes and can feel vibration in the shifter under load, when not under load feels smooth. As soon as I start to accelerate the shaking and vibration comes back?
  3. Big Road Skateboard
    7,280
    41,488
    May 2, 2021
    Not necessarily in the trans. Vibrations travel. Honestly, could be anywhere from the tires forward. No good way to guess without inspecting
    JB7, Last Call and Oxbow Thank this.
  4. Heavyd
    Heavyd Road Train Member
    7,830
    6,281
    Feb 4, 2009
    Start with a basic drive line inspection paying attention to u-joints, spinning caps and loose straps. Check your suspension and u-bolts to make sure you don't have an axle that is coming loose and pitching up excessively when torqued is applied.
    QUALITYTRUCK Thanks this.
  5. DUNE-T
    DUNE-T Road Train Member
    7,071
    17,246
    May 10, 2015
    Detroit, MI
    What engine? On n14 it can be even an injector issue. But yeah, it can be tires, wheels, driveshaft, bearings, whatever
