Material sticking to end dump liner
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Crotts Trucking, Mar 4, 2017.
  1. Crotts Trucking
    Crotts Trucking Medium Load Member
    375
    115
    Dec 23, 2008
    Duncan, AZ
    I have a poly liner and haul copper concentrate, one location I load at is pretty moist. Seems anything I do the material sticks about 5 feet from the front for about 4 feet. What is the best way to fix this? I've heard simple green, I've heard spray diesel. I've thought about sanding the area to 1000 grit. Just not sure. Any ideas? Thanks.
  3. Big Don
    Big Don "Old Fart"
    17,996
    35,645
    Sep 8, 2007
    Utah's DIXIE!
    Dunno about copper concentrate. We certainly used diesel, (if no boss around,) or crusher fines, (if boss in vicinity,) with hot mix asphalt.
  4. abyliks
    abyliks Road Train Member
    4,119
    9,697
    May 2, 2010
    ludlow MA
    They have an environmentally safe release spray that is kind of like a soap that works, don't know what your doing with it but you could always plastic the trailer to
    Crotts Trucking Thanks this.
  5. Big Don
    Big Don "Old Fart"
    17,996
    35,645
    Sep 8, 2007
    Utah's DIXIE!
    ???????????????o_O
  6. Agtrucker
    Agtrucker Light Load Member
    159
    47
    Dec 14, 2011
    It's basically a big plastic bag you lay out in the trailer,goes up the inside walls and often lays over the outside as well.. it's separate from a liner.
    Big Don Thanks this.
  7. fuller
    fuller Light Load Member
    203
    295
    Nov 21, 2010
    Canada
    Diesel spray is risky... If anyone sees you, contaminated load. Vegetable oil I have seen the odd guy use.
    Myself? I climb in the box, and shovel that crap out. My back doesn't like this too often, so I'm going to get a scraper made, which will be just long enough to reach the top of the box.
  8. Big Don
    Big Don "Old Fart"
    17,996
    35,645
    Sep 8, 2007
    Utah's DIXIE!
    Anybody know if they make shakers for end dumps?
  9. fuller
    203
    295
    Nov 21, 2010
    Canada
    I doubt a vibrator would work...
    Had an excavator operator try to "shake" the crap out of my boxes... He couldn't.
    Vibes work well with concrete mixtures and the likes...
    Scraper or shovel is the only solution for us. I try to bill this extra time when customer loads crap, but it isn't always that easy...
  10. Big Don
    Big Don "Old Fart"
    17,996
    35,645
    Sep 8, 2007
    Utah's DIXIE!
    I've only seen the vibrator work on bobtail dump trucks. When I hauled aggregate, the outfit I worked for got a couple of them. I never drove one, but know they worked well for hot mix, and other aggregate products.
  11. Crotts Trucking
    375
    115
    Dec 23, 2008
    Duncan, AZ
    The receiver has air lances and a overhead platform to get up and lance it out. It works, but still 5-10 minutes extra and trucks waiting on you. I pressure washed it and let it dry and then scrubbed it with simple green and let it dry. I just loaded so we will see if I works!
