Max power for overhead cb hookup in prostar/lt
Discussion in 'CB Radio Forum' started by anon6655, Mar 3, 2020.
  1. anon6655
    anon6655 Light Load Member
    237
    52
    Jan 12, 2014
    Looking into running a 10 meter radio. Just wondering if anybody knows the max power the overhead cb power hookup is good for in an international LT/Prostar. Not looking to fry anything
  3. anon6655
    237
    52
    Jan 12, 2014
    And yes it will be convertered. Just need to know max power/highest power you've ran using the green and white cables up top
  4. sbaumann14
    sbaumann14 Road Train Member
    1,238
    1,434
    Sep 1, 2010
    Rhinelander, WI
    When u look in the fuse compartment, it should have a per amp fuse in there. Most are 10-15 amps. Dont know what wattage you can run off that, but u should be able to find something on line
  5. sbaumann14
    1,238
    1,434
    Sep 1, 2010
    Rhinelander, WI
    Im pretty sure that voltage x amps = watts
  6. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Personally i would increase power wire ga (true awg 10 ga)and run direct to battery...Give that radio all it need when you ask..
    BUT thats just me..
    That shady ole cheap crap in these trucks use is junk..
