Maxxforce 13 derated...have codes
Discussion in 'International Forum' started by DirtyDog13, Jun 7, 2019.
  1. DirtyDog13
    DirtyDog13 Bobtail Member
    12
    5
    May 8, 2018
    2012 Prostar, Maxxforce 13, was losing power and codes were lighting up pointing to the DPF. Truck has just under 450k miles so I decided to install new DPF, DPF Pressure sensor, DPF I/O temp sensors. Removed DOC and preDOC and cleaned and reinstalled. Truck is still limping and these are the new codes.
    3223 05
    3246. 03
    3251. 04
    4766. 03
    4765 03
    I believe some of these codes are referring to sensors I just replaced. Any suggestions would be appreciated.
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Did you reset the ECM when you did the new installation?
  4. DirtyDog13
    12
    5
    May 8, 2018
    Yes, removed battery cables for 30 minutes
  5. Heavyd
    Heavyd Road Train Member
    7,826
    6,275
    Feb 4, 2009
    Clear your codes and run the engine to see what comes back.
  6. DirtyDog13
    12
    5
    May 8, 2018
    Cleared codes, same result. Went to dealer and it turned out to be the O2 sensor. Which was the one code I didn't do anything about. Was told I needed a "special" tool to remove it so I let the dealer do it for $1000. Back on the road now.
    Heavyd Thanks this.
  7. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    $1000 for an O2 sensor? And I thought the price was high on a passenger vehicle!
  8. 2013Maxx
    2013Maxx Light Load Member
    137
    42
    Jan 17, 2018
    Where is the O2 sensor located?
  9. ChuckMartel
    ChuckMartel Light Load Member
    160
    94
    Jan 22, 2021
    Just behind the low pressure turbo close to the Aft Inj. It needs to be calibrated.
    2013Maxx Thanks this.
