Maxxforce 7 DPF problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Tomlang, Sep 21, 2013.
  1. Tomlang
    Tomlang Bobtail Member
    6
    Sep 21, 2013
    Montreal, Canada
    hi, my customer have an international with a maxxforce 7 and the problem is that when we want to clean the particul filter with the parked regeneration, it didn't work.
    the procedure to do this task is to star the engine at idle, no engine temperature needed, parking brake apply, transmition at neutral and finally when all this is OK, just press the parkd regen switch.
    Normally, the light on the switch goes ON, but mine is flashing like 4 or 5 times and turn off, no regen have started.
    I dont know where to star to find this problem. I've got the international servicemaxx software and i can do a forced regeneration with the computer, but my customer said that by the time he bought his truck, he had never did the regen cause the switch didint work. his truck is a 2007.
    i'm sorry for my perfect english, i'm originally french, thank you.
    Best regards, Tommy
  3. Heavyd
    Heavyd Road Train Member
    7,828
    6,277
    Feb 4, 2009
    Is the truck requesting a regen? It will not start one if it senses it doesn't need it. Any fault codes?
  4. NFDDJS
    NFDDJS Light Load Member
    267
    37
    Jul 8, 2012
    New Hampshire
    Leave it alone! Just leave the switch on so it auto regens and drive it. You start messing around and that is when you will have a problem...
