Maxxforce DT (466) low power
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Brandon_KHO, Jul 2, 2019.
  1. Brandon_KHO
    Brandon_KHO Bobtail Member
    6
    I just bought a 2012 international 4400 with the maxxforce dt in it. Has 52,000 miles. 5spd Allison trans. Thing felt fine when I test drove it. Would do 70-75 mph no problem. Got it home, hooked up my 40’ flatbed gooseneck and the thing wouldn’t do 55mph floored with the trailer empty. Was blowing black smoke out the exhaust and it has the DPF system. Also getting the diesel exhaust smell pretty bad in the cab. No fault codes, all filters are new, turbo boots are good and can’t see anything cracked or wrong with the intercooler. Any ideas?
  3. Navtech
    Navtech Light Load Member
    62
    43
    May 9, 2019
    For the exhaust smell check the Exhaust back pressure valve/down pipe sometimes on those the pipe on the outlet of the EBPV is hard to get to seal off
    Check the boost control tubes there is one that runs from the intake throttle valve adapter over the valve cover to the boost control solenoid which is mounted on the pipe between the low and high pressure turbos all of the boost control tubes are connected there make sure none of them are broken.
    Is it a High horsepower DT? If it is it will have an additional intercooler on the valve cover, also check that the IMP sensor or the bore it is mounted in is clogged with soot, it’s in the intake manifold it is a 3 wire sensor the 2 wire beside it is manifold temp, also check to see if it has been converted to open crankcase system. If it hasn’t been done there will be about a 3/4-1” hose attached to the 90* air inlet elbow at the low psi turbo, if it hasn’t there is a good possibility the turbos are coked, and not all serial number engines are allowed to be converted. Worth checking into. If it hasn’t been I would recommend it, even though it’s somewhat pricey on the front end.
    shogun and FlaSwampRat Thank this.
  4. Brandon_KHO
    6
    Thanks for the reply Navtech. Yes it has the extra intercooler on top of the valve cover. When I first got the truck I did find the vacuum hose end was broke that runs from the throttle valve over to the other side. I fixed it but didn’t notice any change. I will check this other stuff as well. Is there by chance a YouTube video or something explaining how to convert over to an open crankcase system?
    Thanks
  5. FlaSwampRat
    FlaSwampRat Road Train Member
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    Have you tried a parked regen? You said you have done 70mph so it should have done it on its own but maybe for some reason it hasn't. I have had some Cummins engines years back that needed a forced regen even tho they got highway time. Low power, smoke, and your eyes would burn like crazy from the bs. Not saying that is 100% your problem buy it doesn't hurt to try before taking it somewhere or starting to throw parts at it.
  6. Navtech
    62
    43
    May 9, 2019
    The thing about the conversion is there are different kits available depending on engine serial number, CCOS number, and wether or not the valve cover is baffled some kits require to change the ECM, you really have to have a dealer check it, and like I said some serial numbers are not eligible, if you can send me the last 8 of the vin I can check if that ESN is eligible
    FlaSwampRat Thanks this.
  7. Brandon_KHO
    6
    Oh gotcha. I’ll have to check into then.
    Last 8 of the vin CJ597690
    I appreciate the help tho. It’s nice to be able to get other people’s expertise on here.
  8. Navtech
    62
    43
    May 9, 2019
    That ESN is eligible, check to see if it has been done coked turbos and CAC system can cause the issue that you are having.
  9. Brandon_KHO
    6
    Well come to find out the truck has already had the open crankcase conversion. Went ahead and cleaned both turbos again, had a guy come check it with his laptop. Said everything was great, builds to 35psi boost, ipc’s? Look good and no codes or faults at all... but it still rolls black smoke anytime your on the throttle hard and the thing shifts way early... so I’m stumped..
  10. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    If you see black smoke, your DPF is toast. Some black smoke is normal at hard acceleration, you just don't see it much anymore because of DPFs. Are you still experiencing low power?
    spsauerland Thanks this.
  11. Brandon_KHO
    6
    Yes well I think it’s low power. Truck shifts early st around 1900 rpms as well. Have to shift it manually to gain speed loaded.
