Maxxforce, starting in cold weather? (High RPM's?)
Discussion in 'International Forum' started by tracyq144, Dec 27, 2012.
  1. tracyq144
    tracyq144 Heavy Load Member
    884
    546
    Feb 15, 2009
    MN
    2012 model.
    Here's the deal: When truck has been off, say overnite or so, and the OAT is approximately 30 deg F or less, I start the truck, and it idles around 6-700 for a few seconds, and then jumps to 1600 RPM or so! I've been driving cars and/or trucks since '66, and always figured it was best to let the engine and oil warm up a bit before revving so high?
    Oil pressure gets as high as 80-90 psi during this high idle phase.
    Anyway, do ALL maxxforces behave like this? I ask my mechanics this question, and they just shrug their shoulders.
  3. mitrucker
    mitrucker Road Train Member
    5,564
    10,583
    Dec 15, 2010
    Lapeer, MI
    I have driven four of these trucks and they all do it. It's a normal thing. If you let it go withut knocking the idle down, it will eventually go back down on its own.
  4. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,383
    Jul 16, 2012
    Bentonville Arkansas
    its normal for maxxforces. i dont drive any of em cuz all of the ones i have seen do the same. our company is doing away with the maxxforces.(They suck)
  5. tracyq144
    884
    546
    Feb 15, 2009
    MN
    OK, glad to hear they all do that. Thanks for the replies.
  6. mitrucker
    5,564
    10,583
    Dec 15, 2010
    Lapeer, MI
    Hows this for "they suck"............Mine blew up at 49995 miles. Put a hole in the block and everything. Throttle stuck wide open while it was warming up. Turned off the key and it kept running.................for about 10 more seconds, then BOOM!!!! I am getting it back next week. i know, what the hell am I thinking??????? It's still my truck. I must be getting old, change is just too darn hard.
  7. Dutch
    Dutch Light Load Member
    194
    58
    Commiefornia
    sounds like you had a failed turbo and it ran off the oil passing thru the turbo
    2013Maxx Thanks this.
  8. tracyq144
    884
    546
    Feb 15, 2009
    MN
    I had the same thing happen the first time I started mine in cold weather, but it only had 10000-11000 miles on it at the time. Happened a couple of times, and then never again (125000 on it now). Looked for signs of damage or smoke stains, nothing. Scared the crap out of me, though!
    Maxxforce's are strange beasts, indeed.
  9. Mr. Truck Fixer
    Mr. Truck Fixer Bobtail Member
    46
    13
    Jan 27, 2012
    Ontario
    it is normal, it's part of fast warm up stategy in the programing, and it helps reduce aftertreatment problems. you would think they would let it idle a minute or two before reving them up but they are the engineers.
