Maybe someone hear has a answer rear lights not working.
Discussion in 'Ask An Owner Operator' started by Shutupandkeeptruckin, Dec 26, 2019.
  1. Shutupandkeeptruckin
    Shutupandkeeptruckin Bobtail Member
    21
    Dec 12, 2019
    I have a 2007 Volvo vnl 670 that shows a code say reverse light short circuit..
    I purchased a new set of rear lights from the store. The lights don’t work at all now.. I noticed that once I turned on the hazard lights and there was no response from the rear.
    What can be the issue.
    truckdriver31 Thanks this.
  3. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    are they the right lights and did you install them correctly
  4. Spyro2112
    Spyro2112 Medium Load Member
    623
    433
    Mar 17, 2018
    Fuse,. Broken wire bulb
  5. Cabinover101
    Cabinover101 Heavy Load Member
    726
    1,166
    Jul 28, 2019
    Check your fuses and your wiring at the rear. Make sure there are no barely wires chaffing causeing the short. Winter can be very harsh on rear light wiring, road salt and grime if you run in bad weather also extreme vibration at the rear of the truck
  6. spyder7723
    spyder7723 Road Train Member
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    Check the fuse and that there is power at the fuse then check for power at the transmission switch. Finally trace the wiring from the transmission switch to the light.
    blairandgretchen and feldsforever Thank this.
  7. Flat Earth Trucker
    4,316
    16,622
    Nov 19, 2018
    I recently had a similar issue with my company tractor brake lights not working on my company 2018 Peterbilt 579.
    The shop checked the fuses and other usual suspects, but came up empty.
    Anyhow, the tractor was taken to a dealership for repairs. I don't know what repairs were performed, but I am guessing a few wires were replaced as I noticed that the rubber flooring was reinstalled poorly indicating a not-so-quick repair took place.
    My suspicions are that the previous driver caused an electrical short by overloading one of the 12v outlets.
    May your repair be simple and not costly.
  8. Spyro2112
    623
    433
    Mar 17, 2018
    Break switch on break pedal
  9. Ridgeline
    22,730
    123,549
    You guys know that there are relays that are in line for the power to the lights, this is to allow power distribution design based on loads.
  10. Cabinover101
    726
    1,166
    Jul 28, 2019
    Typical Dealer BS. Stuff like that always burns my hide, for the amount of money that they charge. You should get it back without any flaws to the work that they preformed
  11. AModelCat
    164,847
    The truck threw a fault for SHORT CIRCUIT. That means a wire has rubbed thru on another wire or against a metal part of the frame/cab. If it was a blown fuse or broken wire, it'd read OPEN CIRCUIT. The truck already diagnosed the fault lol. You just gotta find the short. Because there is a fault for this issue, that indicates that the circuit is controlled by a module. In the event of a short, it won't even send power to the circuit once it detects the amperage draw is too high.
    tallmon and Cabinover101 Thank this.
