MBE4000 Cooling Fan Problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Porkchop, Apr 17, 2013.
  1. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    Sorry. Missed part where you said it was MBE 4000. It therefore has a "normally open" solenoid. This means at rest air passes through to fan clutch keeping it disengaged (off) Do like Swaan says and use a toggle with a ground to ground wire on solenoid to activate fan. You will not hurt ECM.
  3. Porkchop
    Porkchop Light Load Member
    73
    11
    Jun 30, 2009
    Whiteville, NC
    Ok, here's what I did for anyone else interested...
    The solenoid has two wires, marked on the plug itself, A and B. Wire A is the positive wire and wire B is the ground. With it connected to the solenoid, wire A shows the running voltage of my truck, 14.2 volts. Wire B shows 2.6 volts, I don't understand why but it does. If you disconnect the plug and check it again, wire B shows nothing. This is checking the wires coming from the truck, not the actual solenoid.
    I took wire B and cut it. I ran the wire from the truck wiring to a switch with 3 poles and two positions. The wire from the solenoid, I ran to the switch also. The wire going to the solenoid I put on the center pin of the switch and put the trucks wire (from the ECM I assume) to one of the outside poles. The other outside pole, I ran a wire from it to a chassis ground.
    Like this, in one position, the solenoid is basically as wired from the factory and flipping the switch changes it to a grounded state and disconnects the wire from the ECM. I wanted to make sure I wasn't grounding that wire from the ECM since I was seeing that 2.6 volts on it for some reason. The fan works off the ECM in one position and manually ones on in the other. The only issue is when manually engaged, the check engine light comes on. I'm assuming this is because there is no feedback to the ECM and maybe this could be resolved with a capacitor of some sort, not sure. Soon as I flip the switch back to normal mode, the check engine light goes off.
    So, so far so good. Thank you guys for answering and giving me the information I needed. Maybe this will help someone else too.
    txhotdeal Thanks this.
  4. TBAR
    TBAR Bobtail Member
    Oct 9, 2017
    I have a 2007 freight liner Columbia with the MB it use to run no more than 200psi now its running at 230 psi with the temp.. light coming on.how do i know whether its my clutch fan or the clutch fan solenoid?
  5. txhotdeal
    txhotdeal Bobtail Member
    fixing to try what u do...did u grd out the 2.4 volt side only on 1 side..or...did you do the 14 volt side on trk side to create/or nullify circuit?...can u do diagram..not sure if i can get it wrong..i do super heavy..or 130k..sometimes i need fan or want fan kick in..even tho does @ 205ish etc...maybe higher....not wanna fry that engine...not many like this engine..not sure why...i think?..they have parameters set to keep it from performing...etc...u'r sketch...would be helpful...i know sounds simple...i guess i can xperiment...best luck 2 ya...& i do realize u stop air to selenoid/fan..kicks n fan....like a brake on trk..if anyone knows & aren't asleep by now..do u know what egt should/could be max before bad news on mbe 4000...i not remmeber...i hav egt guage...i think higher than some as per pitsburgh performance who no deal in these motors...nuff sd...
