MBN c15 broken exhaust rocker help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Kmils09, Apr 19, 2019.
  1. Kmils09
    Kmils09 Bobtail Member
    20
    Jun 17, 2018
    So, one of my spare tractors is a 2004 t800 with a mbn c15. A couple weeks ago it broken an exhaust rocker, cyl 4. I got around finally to changing it, adjusted all valves and injectors etc. Now i started the truck and it runs rough and smokes grayish white. I am trying to see if I missed something or if something else is hurt. Now I have read that the valve bridges can get damaged from this, not sure. Any help is greatly appreciated. Thanks guys.
  3. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    That's what it would seem to be. Pull off the exhaust manifold and see if cylinder 4 is passing smoke & that should let you know.
  4. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
  5. booley
    booley Road Train Member
    1,449
    9,895
    Feb 16, 2008
    I had a '05 C15. Broke exhaust rocker 2 different times. The truck was new enough that Cat made good on them. The second time, Cat replaced all of them...I heard rumors about inferior (mexican or chinese) rockers. The first one that broke, I actually had to still drive a little before I could shut it down, but don't recall what Cat replaced (if anything) besides the rocker. When the second rocker broke, I shut it right down.
