MBN c15 engine info
Discussion in 'Peterbilt Forum' started by young trucker12, Sep 20, 2018.
Page 3 of 4
If you want some good info on Cats, check out Adept Ape on you Tube; lots of good, informative vids about them.
young trucker12 Thanks this. -
Are you sure thats a mbn? I have a 04 mbn single turbo and it looks totally different.
young trucker12 and Zeviander Thank this. -
2002 CAT with no mention of rebuild at 1.1 million miles (the motor looks repainted, but why would they not say it's rebuilt?).
I've been seeing elog-exempt 379's with 3406E CAT's come up on the Peterbilt Enthusiast page on Facebook for 30-45k in decent shape, nothing spectacular, but no need for repairs. I'm not sure why this guy thinks his 2002 is worth way more than that just for being properly detailed but if he thinks 55k is too low, I'd say look elsewhere.
And if it's been rebuilt, dumping money on a rebuild doesn't magically raise the value of the truck by that much. Just like throwing 100k at a bunch of custom accessories doesn't make a 150k truck into a 250k truck.
Motor (rebuilt) is worth $25,000 (most people don't seem to understand that this is what the truck uses to make the money), truck around it is worth $10,000-15,000. At most that's a $40,000 truck.
No offense to the seller, but I've seen '80's 359's with Corvette dashes in better shape with 3406B's under the hood going for $30,000-35,000 on that page. In just as good of shape. And that's the seller's asking price.young trucker12 and SAR Thank this. -
The front end of the motor has me thinking BXS/MXS but the oil filter location and the priming valve says MBN/6NZ. But it doesn't have an older style power-steering system, and it doesn't have the twin belts. It's almost like it's a frankenmotor of different CAT's just from the two pictures there is.
Might be a custom job.Muddydog79 and SAR Thank this. -
yes sir. i called and asked and that’s what they told me
If i were you i would get them to give you the serial# off the engine to be 100% sure. It should have mbn in it.young trucker12 Thanks this.
I think thats a 6nz???young trucker12 Thanks this.
i called and it did start with MBN. they confirmed it wasn’t the 6NZ. what makes y’all think it’s a 6NZ??
Maybe its just the way they mount stuff for a pete now that i look at it closer? The fuel filter, oil fill and dipstick, and blowby tube is all mounted in a different spot then on my kw.young trucker12 Thanks this.
Page 3 of 4
