MBN questions
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Freightlinerbob, Jun 7, 2015.
  1. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    Two questions for now, more to follow I'm sure.
    1) Im wondering at what temperature the engine fan should come on and go off.
    2) Also- oil consumption. I had the oil changed on my first trip. It looked like it was overfilled by about 2 quarts. It's now down about 1 quart from that at about 8,000 miles. What is considerd normal oil consumption?
  3. swaan
    swaan Road Train Member
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Ecm should turn fan on at 216
    Every cat I've owned have been down to the add when it's time to change oil 15,000
    So yours is compleatly normal
    They all burn a little bit, more so as oil gets some milage on it
    Freightlinerbob Thanks this.
  4. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    Oil consumption is spot on for that motor nothing to worry about there. I have my fan kick on at 205. You can set it to whatever you want. I think stock was 210 on mine.
  5. Freightlinerbob
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    OK thanks. I didn't notice it coming on at first so I've just been displaying the coolant temp on the readout and using the manual override at the bottom of big hills, of which we have no shortage in BC. But when trucking in the middle I haven't worried about it. Sure don't want to cook this thing before I pay for it.
  6. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    i run an 04 mbn pulling a multiaxle trailer in ont grossing 135,000lbs plus. It was rebuilt 4 years or so ago. it has maybe 400,000 miles on it. i change the oil every 15,000 miles and it always uses 1 to 1.5 gallons in the last few miles before its due for an oil change. It also uses oil when its idled a lot. It also ran hot on the pyro and water temp until i got it reflashed. Now it runs cooler has more power and better fuel mileage to boot!
  7. swaan
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Can you enlighten all of us on how your changing when your fan comes on .
    I do know that the setting on all the low nox files are set to turn fan on at 216.
    Only the early 5ek and 6ts and some 1lw had the cooler 210 or 208 can't remember .
    But that setting as far as I know can't be changed.
    So I'm real interested on how your acomplishing this. Do tell.
    As for the original ?? Your mbn fan will come on automatically when your ecm sees 216 water temp.
  8. swaan
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Sorry I was wrong ;
    Your mbn ecm will turn the fan on at 217
    And it was only the pre low nox files in the early E models that had the 205 temp.
    This also can not be changed.
  9. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    You have to find someone who is smarter than the ECM. They can figure it out. We are not allowed to tell you how to modify the ECM program on here.
  10. swaan
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Well last time I looked into this was 5-6years ago when I was running a 1lw.
    Then guys like pdi and Kurt could not change fan on temp.
    It was set in stone and nothing you could do about it .
    Now apparently it's easy as pie you say .
    Interesting.
  11. rollin coal
    rollin coal Road Train Member
    13,685
    28,160
    Mar 29, 2008
    TN
    Changing the temperature that the engine fan comes on is not an illegal emissions modification so not breaking any forum rules. How is done?
    truckon Thanks this.
