MC # help
Discussion in 'Ask An Owner Operator' started by WREN, Nov 28, 2019.
  1. WREN
    WREN Medium Load Member
    378
    239
    Jul 17, 2017
    Florida panhandle
    Ok guys, I have my own authority that I suspended back in may of 2018. It's over 2 years old and I'm thinking of reactivating it instead of starting a new one and no longer leasing on with companies. Problem I'm having is there are only two companies that will insure in Florida and that's progressive and Berkshire. Neither will insure me because we had 1 inspection the beginning of 2018 which resulted in an out of service because both tires on same trailer axle had a bald spot on them so they shut my truck down and made me switch tires around with a different axle and off I went. Well because it was the only inspection I had and it was an oos I'm at 100% and they wont insure me. Is there a way to remove that?
    HopeOverMope Thanks this.
  3. jland1962
    jland1962 Bobtail Member
    34
    38
    Aug 15, 2018
    If you thought rates were bad in May 2018. You surely won't like them now.
    Bean Jr. Thanks this.
  4. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    As far as the company side is concerned. It only effects score for 2 years.
    I don't know if it'll remove itself till 3 years is up. Like the driver side. But I could be wrong.
    Try the dataq and fight it. But you probably won't succeed.
    WREN Thanks this.
  5. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,211
    Feb 25, 2016
    I-20 LOUISIANA
    This is exactly why fmcsa is supposed to be fixing this mess. I told them the same thing at the truck show. Inspections/oos pretty much only favor the mega companies and barely reflect “safety”. They just reflect scale and proportion ratios. And not really reflecting the whole “purpose” off this system, which is to prevent crashes. If your consistently not getting moving violations, no accidents, then inspections should not be such a warped reality of safety. Just a civil fine, and a fix it ticket.
    You didn’t get any moving violations, crashs’, or fatalities... I’m sure the Mega’s did... chances are you truck is maintained better than the Mega’s are too. Chances are you know your truck better too
    For the most part, they buy a new truck, and just run the wheels off it, and only fixing when the truck can’t move or maybe after enough driver complaints/ fix it ticket.
    You could try Ooida.
    WREN Thanks this.
