Mechanical advice - air pressure issue
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Daxter, Jan 9, 2016.
  1. Daxter
    Daxter Bobtail Member
    9
    Hi. I have a 2002 International 7400 with a DT530. Bendix TU-FLO 550 air compressor, Bendix AD-9 air dryer and a 2 tank system. Truck is only building 25 PSI. Both tanks are getting 25 PSI. The governor is mounted on the compressor and air is coming out of vent. I replaced governor with same result. I removed the line from the air dryer that enters tank and tested. It built pressure to a remote tank quickly and up to 120 PSI with no issue despite air escaping from governor vent. I reconnected to truck tank and still only 25 PSI. No other noticeable leaks. I filled up tanks with a remote compressor to 75 PSI and leak at governor vent stopped about 15 seconds after stopping air input and tanks maintained pressure as long as none was used. Any ideas would be appreciated.
  3. tobie town trucker
    tobie town trucker Light Load Member
    106
    24
    Jan 12, 2011
    Check your bleed off valves. Maybe they are leaking a little until they had enough pressure to close them
  4. Daxter
    9
    Thanks but definitely not an issue. I bled the tanks several times to confirm air in both and can confirm valves are ok. Doesn't appear to be a leak because maintained pressure when tanks were filled remotely.
  5. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    Seems there's something blocking the line into the tank
  6. Daxter
    9
    That line filled a remote tank perfectly
  7. 062
    062 Road Train Member
    6,333
    33,973
    Oct 20, 2013
    You sure that's a vent and not a port,that a plug fell out of?
  8. Daxter
    9
    Positive. Also it built up pressure in a remote tank despite the air amount being released.
  9. mountaingote
    2,026
    7,916
    Sep 22, 2012
    Then there is a problem getting air into the truck tank
  10. Ridgeline
    22,736
    123,604
    We had one hell of a time with one truck and the lack of building pressure. It was giving issues with the governor tripping at 139 psi, and then not cycling so we replaced it and the new one gave us fits, not building air pressure. We replaced the governor, then thought it was the air dryer (cummins system so it had an extra line going to the ad-9), then we looked at the tanks, lines and all of it. The truck was down for two weeks, it was losing too much money. I had it towed to the nearest freight liner dealer, they did more, replaced the compressor but being in the shop at this point with 15 hours of work there, nothing was getting done.
    So I had the truck towed back to the yard and was ready to put it for sale. I started to tinker with it out of frustration and took the governor off, compared to the old one - nothing different. I messed with the replacements that were in the tool box, all looked the same. Near the end of the day, i was looking at the newest one I took off the truck. I decided to remove the plug from one of the two ports on it, move it to the port that control line that went to the ad-9 and moved that fitting to this now open port to see what happened. I put the thing back on the compressor, started it up and .... It built up pressure ... Popping off at 125 or so psi.
    I don't know why this was the case, I spent 30 minutes on the phone with the dealer, another 30 minutes with bendex telling them what happened which they could not or better out would not tell me why. So in the end I ended up with one hell of a loss from it, 5 brand new governors and nearly a new air system on the truck.
  11. Daxter
    9
    Thanks for the detail, Ridgeline. I'm going to look a little closer into that. I tried adjusting the governor a bit but don't like to mess around too much with something I'm not familiar with. I appreciate the help.
