Medical Card Question
Discussion in 'Experienced Truckers' Advice' started by avp12304, Mar 13, 2019.
  1. avp12304
    avp12304 Bobtail Member
    8
    May 28, 2015
    My med card expires soon, I took a dot physical 3 months ago, they only gave me a 3 month till expiration because my blood pressure was right at 140...sup with that? My question is this....if I go in again and I get 140 again (which probably is going to happen) do they revoke your med card all together? One doctor's office said yes....I have a texas class a cdl...also my other question being...I no longer drive trucks, but want to maintain my cdl..on the texas dps website it said that my cdl is downgraded to a regular license if I let my med card expire (which is bs in my opinion) but it also says that if my cdl is downgraded to a regular license solely because of an expired med card..then all I have to do is get a new med card before I renew my license....now being that this is the internet and all...I would feel a lot more comfortable hearing from an actual dps office employee that this is in fact the case...but I cant ever get the dad gum people on the line, I just sit on hold forever...so I guess what I'm asking is, in texas, can anyone here verify that this is accurate? Or am I about to lose my cdl completely? Thanks guys
  3. Tundra670
    Tundra670 Bobtail Member
    47
    114
    Feb 13, 2019
    Take some high blood med a couple days before exam.
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Your Medical 90 day is a flat warning to RESOLVE your BP or whatever issue IMMEDIATELY without medicines ideally within 90 days. Retest clear with issue resolved to get a 2 year or whatever.
    That's one.
    Your license under Tier One Interstate, Intrastate will go away when your Medical Card expires. It's hardwired now as of a few years ago to the CDL.
    What you need to do is go to your home state DMV (After you KNOW your medical expires really soon) ask for a Tier TWO affidavit document and sign it. It's a prefilled format legalease saying you are NO longer legal for Interstate, intrastate trucking without a Medical card, but still "Grandfathered" or allowed under Tier two to defend your CDL that is pretty precious from downgrading. There are restrictions to tier two, you can still drive a 18 wheeler, if it is farm to market really locally at harvest or running dead bodies in a national war attack of a nuclear kind on a city or state. As explained to me by the DMV in Arkansas when I kept Tier two for decades as a grandfathering privilege allowed by the state.
    There are other tiers but tier two is the easiest and most truthful way to defend your CDL A rating from being downgraded after your medical expires.
    When you resolve your BP medical issues without medicine and so on, you retest for DOT physical get a valid one year or two year, go back to the DMV, turn that new Cert in and sign a affadavit to reswear back to Tier One inter state and intra state trucking. Back on the big road you go. Easy peasy.
  5. Truckermania
    Truckermania Road Train Member
    1,185
    1,804
    Oct 13, 2011
    Sturgis,SD
    I don't know Texas specifically but a few years back in SD I let my physical lapse as I was not trucking at the time. My CDL was downgraded to an Intrastate only CDL. It was upgraded back to Interstate when I got another physical. When doing your BP make sure to ask them to let you lay down and relax for about 10 minutes before they take it. It will give them a truer reading. This is standard practice and they should allow you to do it. Best wishes to you!
  6. Tundra670
    47
    114
    Feb 13, 2019
    That’s what they had me do. They had me lay down n relax for 15min cause I was at 142 sure enough I passed 15min later. I asked what would happen if I didn’t pass they said the doc will prescribe me some med and come back a couple days and redo the BP. Good luck
    tscottme Thanks this.
  7. kemosabi49
    10,980
    47,926
    Jan 13, 2013
    SW Arkansas
    You should be able to go into the DPS office and self-certify as "Excepted Intrastate" or "Excepted Interstate". You won't be able to drive but you will keep your cdl. Then when you get your b/p under control you can go back with your new med card and self certify back to interstate.
  8. Ridgeline
    22,741
    123,659
    Hate to say this but unless you went to your doc, got a treatment plan and meds, you will not be allowed to get another pass on this because you don't deserve it.
    GET TO THE DOCTOR.
  9. Numb
    Numb Crusty Curmudgeon
    4,333
    10,298
    Jan 30, 2012
    Charlotte, N.Carolina
    if your BP is that low, the medicine is really cheap to bring down a few points.
    mine is $2.30 for a 30 day supply. with ins.
    without it is about $10.
    no reason to go around with high BP.
  10. LilBudyWizer
    LilBudyWizer Light Load Member
    185
    169
    I don't know about Texas specifically, but my physical expired due to a failed drug test. Well, not exactly, but that's why I let it lapse. When I got the notice I had 20 days to surrender my license I decided maybe it would be best to get one even though I'm not driving. So I got the physical, submitted it and they reinstated it. That, I believe, is federal though the state administers it so should be the same in every state but I can't swear to that.
    I'm not sure that physical is valid. They're not allowed to give you an interim medical certificate while you follow up on a problem. Now they are suppose to mark you pending. You didn't fail so you can continue driving on your existing medical certificate, but you didn't pass so when it expires you can't drive. You can get the physical somewhere else, but that doctor will be able to see you have a pending physical and why so they'll likely ask questions. If they feel you need to follow up they'll mark you pending too. Get several of those and no one will pass you until you do the follow up.
    I would suggest you contact the DOT hotline to see if that medical certificate is valid. If not it isn't your mistake, you did nothing wrong, you aren't likely to be fined, but if a state trooper determines it's not valid you're not driving anywhere until you get a physical.
  11. Woodchuck88
    Woodchuck88 Medium Load Member
    553
    1,103
    Jan 4, 2017
    New York
    Just took one Monday. Nurse did BP and hearing, then the doc looked in my ears and filled out the card, haha best one I’ve ever had.
