Medical info
Discussion in 'Questions From New Drivers' started by littleduck, Jul 21, 2014.
  1. littleduck
    littleduck Light Load Member
    296
    70
    Feb 7, 2014
    caswell county nc
    I was supposed to start trucking school in August already had everything lined up and already had a pre hire with melton truck lines but i have been hurting in my back for about a month and i thought it was because of the type of work i do now alot of heavy lifting twisting and stuff but it got to the point i couldn't take it so i went to the doctor yesterday and he told me i have scoliosis he wouldn't say how bad it was but my question is will this affect me trying to drive a truck i have been looking foward to driving since i was 12 years old and i hope this doesn't get in the way but would i even be able to pass a DOT physical thanks in advance
    Chinatown Thanks this.
  3. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    Just about everyone has that problem when we age. If you take the right precautions you should be able to minimize your discomfort. Go on the net and learn how to lift and exercise your lower back. Take over the counter meds if you have to but beware of Tylenol. There's only so much of that and you could have some liver problems. Take caution and be informed on anything you take. My recommendation is to stay away from prescription pain killers. They may help but to me they're not worth the problems. It's best to exercise and protect your back. Even watching what you eat can help by keeping the weight down. Good luck and be careful and INFORMED.
    sexystuff911 and littleduck Thank this.
  4. littleduck
    296
    70
    Feb 7, 2014
    caswell county nc
    Yea i aint but 20 so thats what worries me and ive been trying to get information about it and i try not to take prescription pain killers except the 800mg ibuprofen
  5. sexystuff911
    sexystuff911 Light Load Member
    205
    177
    Feb 26, 2013
    N. California
    I was on prescription pain killers after a surgery. The swelling wouldn't go down, the wound wouldn't heal, and it hurt more than before the surgery. It was awful... until I tossed the pain killers. Within two weeks, the swelling was gone and I felt like I had a new arm! Take Gashauler's advise... stay away from prescription pain killers!!! They do more harm than good!
    (I later learned that my problem was the pain killers would deaden the pain, and so I was re-injuring my arm before it had a chance to heal).
    crazw and littleduck Thank this.
  6. Chinatown
    Chinatown Road Train Member
    77,965
    185,501
    Aug 28, 2011
    Henderson, NV & Orient
    Get a DOT physical on your own; you will need to do this anyway for school. If you pass the physical, Paschall Truck Lines will hire you without having to take another physical. Most companies require you to take another physical, but Paschall will accept your current card and only require a urine test.
    glenn71 and littleduck Thank this.
  7. Nirvana
    Nirvana Light Load Member
    205
    53
    Jul 5, 2014
    Gloucester, Virginia
    I have ketosis hunch back and it affects me slightly but just gotta deal and be thankful we don't drive non air ride seats and cab overs.
  8. tumblin dice
    tumblin dice Light Load Member
    201
    99
    Apr 18, 2014
    Jacksonville, FL
    There may be some type of back support that may work for you as well.
  9. littleduck
    296
    70
    Feb 7, 2014
    caswell county nc
    They told me that i may can get a brace it just depends on how bad it is
  10. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    Just be careful who you tell about this problem. I believe this should be the only place you can discuss something like this. Companies will use a bad back for discharge in a micro second. If you need to find the problem you'll need an MRI. That's where the doctors will tell you what kind and how bad. The test cost over a $1000 so paying for that may be a problem. Study up on the situation and maybe you can have the test done by your company insurance and still keep it to yourself. I would have to see all that in writing before I went for a test like that. The trucking companies fear that anyone with a bad back will end up suing them and win. It's hard to prove any issue about bad backs. Keep that in mind because if you ever do have a real workmans comp claim they can use any prior condition in their favor. It doesn't even matter if the injury is in a different place on your spine. A bad back means your whole spine to the company.
    Chinatown and littleduck Thank this.
  11. littleduck
    296
    70
    Feb 7, 2014
    caswell county nc
    Thanks gas hauler ima have to look into that cause aint no way i could afford that im going broke trying to go to trucking school and it seems like its set backs after set backs but im not giving up on it
