Medications
Discussion in 'Questions From New Drivers' started by oramac, Jul 21, 2012.
  1. oramac
    oramac Bobtail Member
    41
    54
    Jun 26, 2012
    I did a little searching but could not find the exact answer.
    Is there certain medications that automatically disqualify you from holding a Class A CDL?
    If yes
    Where can I find the list?
    Thanks,
  3. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,981
    Apr 4, 2007
    http://www.fmcsa.dot.gov/rules-regulations/topics/medical/faqs.aspx[TABLE]
    [TR]
    [TD]77.
    [/TD]
    [TD]What medications disqualify a CMV driver?
    [/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]A driver cannot take a controlled substance or prescription medication without a prescription from a licensed practitioner.
    If a driver uses a drug identified in 21 CFR 1308.11 (391.42(b)(12)) or any other substance such as amphetamine, a narcotic, or any other habit forming drug, The driver is medically unqualified.
    There is an exception: the prescribing doctor can write that the driver is safe to be a commercial driver while taking the medication. In this case, the Medical Examiner may, but does not have to certify the driver.
    Any anti-seizure medication used for the prevention of seizures is disqualifying.
    Methadone use is disqualifying.
    The Medical Examiner has 2 ways to determine if any medication a driver uses will adversely affect safe operation of a CMV:
    1. Review each medication - prescription, non-prescription and supplement
    2. Request a letter from the prescribing doctor
    http://www.deadiversion.usdoj.gov/21cfr/cfr/1308/1308_11.htm
    [/TD]
    [/TR]
    [/TABLE]
  4. Wooly Rhino
    Wooly Rhino Road Train Member
    3,367
    5,648
    Jul 6, 2008
    Liberty, Missouri
    Ambien is allowed but shouldn't be.
  5. 123456
    123456 Road Train Member
    10,555
    5,748
    Oct 22, 2010
    32179
    No,
    not to possess a cdl.
    You can take any drug.
    Using a cdl is different.
  6. RickG
    RickG Road Train Member
    12,812
    6,137
    Jul 22, 2008
    Owensboro , KY
    What drugs were you taking when you posted that ? You need a medical card to get a CDL . Use of certain drugs will disqualify you.
  7. 123456
    10,555
    5,748
    Oct 22, 2010
    32179
    No sir,
    there is no drug test to GET a medical card or a cdl............
    Gizmo_Man Thanks this.
  8. sleeve62
    sleeve62 Light Load Member
    75
    55
    Apr 8, 2012
    Rittman, Ohio
    When you report for pre-employment drug testing you are not queried as to any medications you may be taking. The screening test results are forwarded to the Medical Revue Officer, who will contact you about the test results if there is A " hit " on A target substance. If you have A prescription the pharmacy is contacted to substantiate that. If your personnel physician attests , for instance that you have been taking XYZ for over 5 years and he commits that in his judgement that no issue exists, the subject is moot unless you carry it further. HIPPA Federal Regulations prohibit revelation/discussion of A persons medical/health issues without their consent. Again , if you weeded out every citizen in this country based upon his or her use of mood elevators/stabilizers you may as well shut down most of the industries we still have functioning. Look at the ads for drivers and note how the criteria for hire is becoming less and less rigorous. The bureaucrats have been so busy formulating solutions in search of A problem they have effectively disqualified everybody that has ever driven A CMV. You can drive 3 million miles OTR , and maybe not experience an accident or incident. A combination city and road driver has the odds stacked against them. The economy , job changes, insurance companies, legislatures , bureaucrats /enforcement entities ; seems as if there is A movement afoot to shut down the logistics operations and add to unemployment and the depression.
    T...Street and 7-UP Thank this.
  9. T...Street
    T...Street Light Load Member
    182
    176
    Aug 19, 2012
    randolph co. NC
    Makes sense...put a bunch of inexperienced folks in trucks by using the excuse of a "medical condition" to disqualify the experienced folks that the government would have a harder time controlling..... Isn't that called trying to "destroy the industry from within"
    7-UP Thanks this.
  10. chompi
    chompi Road Train Member
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
    Actually they do not test for methadone. Unless specifically asked to test for it it is not on a regular DOT test. It is actually a violation of privacy to do so.
    If you are diabetic that will also disqualify you.
    There are many others, check with the doctor to be absolutely positive.
  11. rlb05g
    rlb05g Bobtail Member
    18
    Sep 30, 2012
    Tallahassee, FL
    They test the 5. Opiates (except most pharmaceuticals except codeine and one other... no hydro/oxycodone), Hallucinogens, Marijuana, Ecstasy, and Amphetamines.
