Melted air purifier
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Zen Trucker, Mar 29, 2013.
  1. Zen Trucker
    Zen Trucker Road Train Member
    1,038
    1,177
    Aug 9, 2012
    I bought an Oreck Air purifier that worked great until the top melted. Obviously, there is some major incompatibility with the inverter.
    I can run my tea kettle fine so I'm sure it is not an issue with not enough power.
    What would cause this?
    I need to buy another one and want to make sure I don't have the same problem.
  3. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    What kind of inverter are you using? if its not pure sine wave it will keep doing this.
  4. Zen Trucker
    1,038
    1,177
    Aug 9, 2012
    I can look at it later but quite sure it is not a sine wave.
    Is there some kind of "filter" I can use?
  5. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    Any filter that you try to use will cost more than the difference between a pure sine and modified sine inverter. And its performance will change dependent on load. Modified sine wave works well for devices that use switching power supplies, but not so much for devices with electric motors, or microwaves.
    You want something like this:
    https://www.google.com/shopping/product/6896692399889765355?q=pure%20sine%20wave%20inverter&hl=en&sqi=2&bav=on.2,or.r_cp.r_qf.&bvm=bv.44442042,d.eWU&biw=1590&bih=743&sa=X&ei=RMtVUb7vKY-u8QTHiYCwBg&ved=0CGcQ8wIwAA&prds=scoring:tp
    Zen Trucker Thanks this.
  6. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Variable speed fan motors don't like modified sine waves. You need a pure sine wave inverter.
    Cobra is a modified sine wave. Every pure wave inverter I've seen says it right on the inverter. Amazon sells pure sine wave inverters.
  7. bubbanbrenda
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    IMO (and just my opinion) xantrex is the only way to go.
  8. Zen Trucker
    1,038
    1,177
    Aug 9, 2012
    Thank you all for your input.
