Meritor 10spd not going into HI range
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by czego82, Dec 28, 2018.
  1. czego82
    czego82 Light Load Member
    160
    44
    Nov 15, 2014
    I have a 1998 Meritor 10 speed. It shifts great but does not go into HI range when switched. Normally when you slip the selector you hear the noise, but now, nothing.
    I drove it home at 20mph for about 30min. After making a stop at the light, and trying to slip to HI range it started to work. I don't want to get stuck in a low range, any idea what it could be? Mechanic told its most likely synchronizer in the back and Meritor makes a kit to fix it. Estmiates $1k for the job...
  3. McMahons Trucking
    McMahons Trucking Light Load Member
    274
    119
    Jul 4, 2018
    Do you hear air escaping out of the valve when you switch from low to high range?
  4. czego82
    160
    44
    Nov 15, 2014
  5. czego82
    160
    44
    Nov 15, 2014
    NO
  6. McMahons Trucking
    274
    119
    Jul 4, 2018
    Might want to start with the air supply the that valve on the tranny. You should hear air come out of the vent.
  7. 25(2)+2
    18,760
    46,011
    Sep 18, 2006
    the road less travelled
    There's a fix for that, someone familiar with Rockwell Meritor , which was very common before about 2005, should be able to put the updated range shift mechanism on it.
    I had one stick in high range, getting it moving is the problem then..
    Another had it stuck in low, he drove a long ways, that way.
    Both were fixed in our company shop, and the one I had lost the fix when they finally replaced the trans with a reman.
  8. czego82
    160
    44
    Nov 15, 2014
    Replace the Slave Valve Assembly?
  9. McMahons Trucking
    274
    119
    Jul 4, 2018
    Yes. It might need replaced or cleaned out. I would replace it with a new gasket. I think they are about 100 bucks
  10. czego82
    160
    44
    Nov 15, 2014
    If the synchro was bad, would there be air noise?
  11. McMahons Trucking
    274
    119
    Jul 4, 2018
    Synchronizer is internal to the tranny. The valve is on the back external.
