Meritor RMX10-135a 10 speed reverse light
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by jeffl0123, Jul 11, 2022.
  1. jeffl0123
    jeffl0123 Light Load Member
    60
    14
    Jan 18, 2018
    Hey everyone,
    Had a question. Wondering if anyone knows where I could view wiring diagram or find the reverse light wire for my truck. 1999 International 8100 with the Cummins M11 and Meritor RMX10-135a 10 speed. This truck was modified and a toter truck bed was put on the back which is the way it is now. The lights are in the body but I cannot find any connectors for it. And I went to the wire box that was put in to run all the lights back to the body but I cannot find any wire that lights up with my test light when in reverse. So not sure how to find this wire. I only found 2 switches on the tranny. One that is right behind the shifter but is power hot when truck key is on and then other one is the one for either rpm or speedo at the output shaft. Not sure where to go from here. Need to take care of this because I was DOT'd the other day and that's the only thing they found and my lease company wants it done ASAP.
  3. Star Rider
    Star Rider Road Train Member
    1,790
    18,720
    Sep 23, 2019
    The one behind the shift tower is your reverse lights. Run a new wire from the one that is not hot with key on to your reverse lights,or look for the broken wire. Easy fix.
    LameMule Thanks this.
  4. motocross25
    motocross25 Road Train Member
    3,890
    11,962
    Sep 23, 2010
    Overland Park, KS
    Coover, Freddy57, JSanborn103 and 2 others Thank this.
  5. LameMule
    LameMule Road Train Member
    1,148
    7,418
    Jan 19, 2020
    Montana
    Most transmissions I've seen have a single wire connector off the top of the housing near the shift tower. If you look up your transmissions model you'll know exactly where the reverse switch is located and you can run a new wire.
  6. Kyle G.
    Kyle G. Road Train Member
    3,903
    20,582
    Jan 23, 2016
    Eastern Iowa
    motocross25 Thanks this.
  7. motocross25
    3,890
    11,962
    Sep 23, 2010
    Overland Park, KS
    Haha! Dude I came back to this thread like 3 times thinking whether I should or shouldn’t make a tranny joke. I couldn’t help myself. I’m weak. :oops:
    LameMule and Kyle G. Thank this.
  8. jeffl0123
    60
    14
    Jan 18, 2018
    Ok thanks. Not sure what I triggered but I will replace that wire on the "transmission".
  9. AModelCat
    164,923
    Merritor might be different than Eaton for reverse light switch location.
    Some trucks never even had that switch installed from factory believe it or not.
  10. LameMule
    1,148
    7,418
    Jan 19, 2020
    Montana
    I'm not familiar with Meritors, I just looked up the model OP stated and outlined where I've typically found that switch.
    I've heard of guys just wiring up floodlights to a switch in the cab and calling it their reverse lights. He could always do that.
  11. JSanborn103
    JSanborn103 Medium Load Member
    514
    5,212
    Jan 20, 2021
    The tranny identifies as a 1999 international? Genders just keep getting more and more confusing
    Kyle G. Thanks this.
