Meritor sealed hub. Can the bearings be replaced?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dadetrucking305, Apr 10, 2025.
  1. Dadetrucking305
    Dadetrucking305 Heavy Load Member
    984
    2,585
    Sep 15, 2011
    Cibolo,Texas
    I have a Meritor axle on a 9900i with unitized sealed hubs. One of the hubs has play and I’m wondering if just the bearings can be replaced ? The hub is $2k smh
    TIA
    @Heavyd
  3. xsetra
    xsetra Road Train Member
    5,205
    7,161
    Aug 21, 2011
    I had the same problem with my 99 freightliner.
    I replaced the entire axle.
    Rideandrepair and Dadetrucking305 Thank this.
  4. Rideandrepair
    17,601
    56,990
    Aug 8, 2015
    What??? My 99 had the grease type steer hubs. They can be serviced.
  5. singlescrewshaker
    5,015
    44,301
    Dec 31, 2017
    Little Havana, FL
    Pretty sure you can snug it up "against recommendation"
    @Tug Toy
    What yours go, another half million? Lol
  6. Dadetrucking305
    984
    2,585
    Sep 15, 2011
    Cibolo,Texas
    Lol, Hopefully I can snug it up. Screw those unitized hubs. Every place I call says they don’t make them anymore and the ones that are still out there want to charge like if they are made of gold.
    singlescrewshaker Thanks this.
  7. Big Road Skateboard
    7,634
    44,055
    May 2, 2021
    You can replace the bearings. I would remove the cone and adjust the bearings normally.
    One thing, the part #'s on the bearings in your hub may actually be unavailable, but they can be replaced with standard bearings and races, without the cone.
    BoxCarKidd and singlescrewshaker Thank this.
  8. xsetra
    5,205
    7,161
    Aug 21, 2011
    Yep this was the only one of the 3 99FLD's I owned, that had the sealed hub. With 1 hub going bad. The other probably was not far behind.
    I chose to replace entire axle with new hubs, races and bearings. King pins were good. Took to alignment shop. All was good to go.
    That fix was quicker than ordering and waiting for a new sealed hub. I was told the Hub needed was not an off the shelf item. I would have to wait for a production run to get.
    BoxCarKidd and Rideandrepair Thank this.
  9. Rideandrepair
    17,601
    56,990
    Aug 8, 2015
    Nice to have all that new.
    xsetra Thanks this.
  10. Heavyd
    Heavyd Road Train Member
    7,839
    6,295
    Feb 4, 2009
    Those hubs are not the same as current preset style bearings with the inner cone spacer. This original generation is not serviceable and the hub needs to be replaced.
  11. Big Road Skateboard
    7,634
    44,055
    May 2, 2021
    I have never seen a hub of that style before. Thanks for posting. Anybody know if all the axes listed in that bulletin used that style hub?
    Rideandrepair Thanks this.
