Meritor transmission leaking from back box
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by henboy1, Jul 4, 2020.
  1. henboy1
    henboy1 Medium Load Member
    332
    139
    Mar 26, 2011
    stockbridge
    I am not ready to have them drop the transmission to fix a leaking back box . Can anyone recommend an additive to slow this leaking transmission? . Meritor 10 speed in a 60 series detroit
  3. Goodysnap
    Goodysnap Road Train Member
    3,775
    9,202
    Jul 12, 2017
    No additive will fix the leak. Snake oils that claim to do so will be temporary.
    Keep it full with the correct lube and fix the leak as time allows.
    pushbroom Thanks this.
  4. henboy1
    332
    139
    Mar 26, 2011
    stockbridge
    What about the engine that was leaking? Lucas stop leak fixed it ......rear main seal , rear and front cover seal , it fixed all on both trucks . Sit back and watch , I will find one for a transmission leak .chasing leaks on a detroit 60 series will put an owner operator out of business
  5. Goodysnap
    3,775
    9,202
    Jul 12, 2017
    Why are you asking for recommendations if you already have a magic potion in your pocket that fixes trucks? Theres a ton on this in the archives and everyone here knows my stance as stated above. Happy pouring.......
  6. haycarter
    haycarter Road Train Member
    1,920
    5,317
    Jun 9, 2012
    Australia
    You need to Check that Gearbox Breather is not Blocked, as this can cause It to Leak..
    spsauerland Thanks this.
  7. henboy1
    332
    139
    Mar 26, 2011
    stockbridge
    How and where is it located ?
  8. henboy1
    332
    139
    Mar 26, 2011
    stockbridge
    Ok , I looked online and found the breather location . It's on the top cover . The leak is by the drain plug and how and why would a breather cause a leak ?
  9. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    If vent isn't relieving case pressure, internal pressure will increase and cause oil to be forced out of the weakest link.
    Hulld, lwlevens, haycarter and 2 others Thank this.
  10. Tony2019
    Tony2019 Bobtail Member
    6
    I have meritor transmission it grinding when I shifting high to low or even high to neutral
    10 speed freightliner century 2007 900xxx miles
    Any body have any idea
    How much does it cost to get fix
    Thank you your help is really appreciated
  11. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    Unless you have X ray vision,there is no way to know what is worn out on your gearbox.
