MFJ Analyzer Question
Discussion in 'CB Radio Forum' started by delta5, Aug 16, 2017.
  1. delta5
    delta5 Road Train Member
    1,193
    7,404
    Sep 9, 2010
    I just installed a 4ft Francis fiberglass whip on the new cascadia I driving. It's mounted on the pass door with a custom mount made for where that spot mirror goes above the window. My analyzer shows 1.6:1 match, 50 ohms on impedance meter and x=22. The noise from the speaker gets lower when I touch the radio. I'm wondering if some bonding is needed from door to door frame?
  3. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Yep....x=22 ain't all that good either...X needs to be 0.
    May run a ground strap off the radios mounting bracket, or from one of the radios side mounting screws to a good grounding point under the dash somewhere too.
    rabbiporkchop Thanks this.
  4. rabbiporkchop
    9,678
    6,546
    Feb 9, 2012
    Wapwallopen, Pa
    @ what frequency does X=zero?
  5. delta5
    1,193
    7,404
    Sep 9, 2010
    Not sure. I will have to check that tonight.
  6. rabbiporkchop
    9,678
    6,546
    Feb 9, 2012
    Wapwallopen, Pa
    If x=zero and r=28 at a usable frequency, a shunt match can make r=50 without affecting X.
  7. VolvoTerry
    VolvoTerry Light Load Member
    293
    377
    Sep 7, 2015
    Based out of Omaha,NE
    Did you fix this issue? I used a similar set up a few years ago and found grounding strap from the door to the cab to the frame solved the issue.
