Mic not working
Discussion in 'CB Radio Forum' started by Life on Wheels, May 10, 2020.
  1. Life on Wheels
    Life on Wheels Light Load Member
    198
    177
    Aug 17, 2019
    New Orleans, Louisiana
    Hey y'all. Just got a new truck with new CB in it. I can hear everyone talking on ch 19, but they can't hear me. Any thoughts?
  3. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Could be your mic...could also be skip your hearing in which case they probably won't hear you unless your running some power.
  4. Night Stalker10
    Night Stalker10 Road Train Member
    1,699
    1,271
    Jun 26, 2017
    What type and model of radio? Do you have the mic gain all the way up? When you talk, did someone verify that your radio has RF output by watching their radios meter?
  5. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    We need all the details you can offer..
    Truck
    Radio
    Antenna
    Coax
    How its powered
    Radio settings
    If radio has been worked on
    We need the works to be able to hone in on the possible issue..
  6. Life on Wheels
    198
    177
    Aug 17, 2019
    Sorry this took so long to respond to. I didn't get an alert that you replied. I have the gain all the way up. The CB is a Cobra, but I don't know the model bc I'm not in the truck (4 day vacation).
    I'm in a brand new 2021 KW T680.
    Two things I notice:
    I tried to calibrate it, but the meter dial never moves to the right.
    Also, when I press and hold the mic button, a green light on the CB turns red.
    Does this help?
  7. Life on Wheels
    198
    177
    Aug 17, 2019
    Sorry this took so long to reply to. I didn't get an alert that you responded.
    Unfortunately, I don't have all the info bc I have 4 days off, and I'm not in the truck.
    I have a factory installed Cobra (don't know the model number) in a 2021 KW T680.
    I watched some YouTube videos on setting up a new CB, and followed them. Gain is up. Volume up, squalk adjusted.
    When I press and hold the mic, a green light turns red on the CB.
    Also, I tried to calibrate it, but the meter doesn't move to the right.
  8. BigJim63
    BigJim63 Light Load Member
    62
    61
    May 1, 2014
    Evansville In.
    Is the cb/PA switch on cb?
  9. Life on Wheels
    198
    177
    Aug 17, 2019
    Yes, it's on CB
  10. Night Stalker10
    1,699
    1,271
    Jun 26, 2017
    Ok, sounds like a Cobra 29. You say the meter needle doesn't move in calibration mode. Does the needle move in sr/f mode? If it doesn't, you may have a bad/ broken wire in the microphone, or the radio has a problem.
  11. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    If the cal knob is not turned clockwise while in cal mode the needle is not gonna move if i remember
