mic zapped me.
Discussion in 'CB Radio Forum' started by Logan76, Sep 20, 2011.
  1. Logan76
    Logan76 Crusty In Training
    4,528
    17,698
    Jul 12, 2009
    kittanning, PA
    I got a free cobra 29 classic off my friend, I put a red/white/blue faceplate on it and had a very respectable cb shop put an rfx75 on it. I pulled out the general lee to give one of these new rfx75 monsters (or so people are saying) a try. I just put brand new mini 8 coax in my truck and i'm talking on my astatic 636l mic and the little spring on the bottom of the mic shocked me or burnt me twice. What could my problem be? :biggrin_25513:
    The radio is also feeding back through my trucks stereo speakers, and no the coax isnt routed near the wires and the power for the radio is straight from the battery and is an old extension cord so its shielded and away from most of the major wire looms in the truck.
  3. AB7IF
    AB7IF Light Load Member
    205
    103
    Jun 11, 2011
    Somewhere, Ar
    Your antenna system has no or little ground, SWR is high, and RF voltages are floating all over. Soon the mosfet final will fail so the problem will be gone anyway unless you fix the antenna system before running power.
    rabbiporkchop Thanks this.
  4. dave26027
    dave26027 Road Train Member
    1,284
    804
    Sep 10, 2009
    Dallas, Texas
    Yup- ground that antenna!
  5. captw900
    captw900 Light Load Member
    174
    47
    Aug 22, 2011
    buffalo,Ny
    Any time that's happened to me it was faulty ground washer at antenna base you are the ground when you get stung
  6. Phil1Fla
    Phil1Fla Light Load Member
    298
    53
    May 12, 2008
    Beavercreek, Oregon
    You got an RF burn. Makes sure that the radio is grounded. Also have the mike cord checked you might also have a lose wire in the case that is grounding out to the case making the mike cord hot. RF burns are no fun But be glad you were using a CB set with low power. It will smart a lot more if you were using some of the basic power us HAMS use.
    Remember if they want to much for the radio check out most CB sets run about $100.00 or less depending on what you want.
    Just had a thought check out your antenna system you might have a short causing the RF to be dumped to the mike cord and the case.
  7. Logan76
    4,528
    17,698
    Jul 12, 2009
    kittanning, PA
    I don't mind spending the time to run separate ground straps, antenna mount to mirror, mirror to door, door hinge to cab and cab to frame. My only problem is finding nice 1" wide copper braided ground straps in differing lengths. I can't find the dern things anywhere!
  8. mike5511
    mike5511 Road Train Member
    3,140
    1,523
    May 15, 2011
    NW Arkansas
    You are so right. Check the WWW or junk yards. Diesel Pick-ups have some under the hood. Old police cars also have them in the trunk. (that's where I got mine.)
  9. Logan76
    4,528
    17,698
    Jul 12, 2009
    kittanning, PA
    what if i was to take the mount side off of two mirror mounts and mount them back to back of eachother making a single mount, then run my wilson 2k up and a tigershark 4 foot steel whip pointing straight down, that in turn would make me a dipole like there was a thread on here about not too long ago. would that solve my issues?
  10. mike5511
    3,140
    1,523
    May 15, 2011
    NW Arkansas
    It might help. Just have to experiment and see. Just make sure the antenna pointing down is grounded out to the bracket, i.e. don't use the little plastic washer/spacer.
  11. marmonman
    marmonman Road Train Member
    1,417
    2,842
    Dec 14, 2009
    central illinois
    Check out farm supply stores look in the battery area they sale the ground straps there for tractors .
    You can check out ham radio stores online too .
