Microwaves & Inverters
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Lonni, Feb 11, 2016.
  1. Lonni
    Lonni Bobtail Member
    I have a small space saver Whirlpool microwave 700 watts I have a 2500 watt inverter without 5000 watts peak the microwave works on house current fine but when I plug it into the inverter light comes on table turns but doesn't heat anything up if anyone can help me without this problem please email me at [email protected]
  3. antoinefinch
    antoinefinch Light Load Member
    187
    120
    Jan 23, 2015
    Phenix City, Alabama
    do you have inverter hooked directly to battery,if so may need pure sine wave inverter it would be strange? need more info
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    Try and cook some thing in it. I run a 1000 watt off of a 2000 watt inverter and it works fine. Takes a little longer to cook compared to 110 from the house.
  5. Travisroland
    Travisroland Light Load Member
    236
    139
    Apr 2, 2015
    I have a fridge and a microwave on my cheap 1600 watt whistler inverter.Works fine.You don't have some thing hooked up right or that inverter is no good.I like this Whistler inverter
  6. scottlav46
    scottlav46 Road Train Member
    1,007
    6,430
    Jun 18, 2015
    Escanaba, MI
    I prefer a toaster oven never had a problem heats better than a microwave and best of all I'm never tempted to whip up a batch of that nasty microwave popcorn thinking that somehow Orville redenbacher finally made it less vile
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Is the wiring large enough to supply the inverter ?
    Some items require a pure sine wave inverter, but I've never had a problem running a microwave on a modified sine wave inverter.
    I had one microwave that would do what yours is doing, just turned out to be that the door wasn't completely closing properly.
  8. MidWest_MacDaddy
    11,409
    19,508
    Feb 21, 2015
    South Carolina
    I just changed trucks and my microwave worked fine in my other truck... Turns out in this truck I have to have the engine running to power the inverter to supply the microwave with enough power to actually run.
    So, maybe try it with the engine running?
    That's all I got... Good luck!!!
  9. Lonni
    Thanks for all the replies but it works fine with other Microwaves just not this whirlpool space saver I just purchased
  10. MidWest_MacDaddy
    11,409
    19,508
    Feb 21, 2015
    South Carolina
    Return it... :)
  11. Lonni
    I tried to but the place where I purchased it are being a$@hol@s and willi not allow appliance to be returned
