MID 136 SID 66 FMI 7 traction control light on HELP!!
Discussion in 'Volvo Forum' started by Elroythekid, May 3, 2014.
  1. Chip_k
    Chip_k Bobtail Member
    Having this exact issue with a 2015 d13 tractor, any thing ever fix your issue?
  2. Elroythekid
    Elroythekid Road Train Member
    2,621
    5,675
    Sep 9, 2010
    Halifax Nova Scotia
    Bendix decided it was a conglict between their soft ware and volvo software for the holl assist. They finally came up with new software and my desler installed it and no more light. But.... the hill assist became very agressive, it would come on a lot more, sometimes when I wasn't even on a hill just backing up in a parking lot. It became second nature to just hit the off button. They said you couldn't disable the hill assist completely. PITA.
  3. Broke Down 69
    Broke Down 69 Road Train Member
    2,733
    9,772
    Jul 3, 2016
    Concord NC
    My truck, 2013 KW T700, is in the shop for that exact problem. As suggested to you earlier it was a broken tone ring.
  4. abnormal
    abnormal Bobtail Member
    sorry it is soooo late. but that would just require the dealer updating their bendix vendor software before giving it a software update using Premium Tech Tool. that is volvo's software. ps... that is if you have a volvo. i went through this issue before.
  5. abnormal
    it is the volvo dealer that must update the vendor software downloading it from the trucksdealerportal.com then they can go into Premium Tech Tool (volvo's software) and update the brake ecu software from volvos software. not bendix.
  6. svraka
    svraka Bobtail Member
    9
    Feb 25, 2015
    I have Volvo VNL 630 with D12 engine this code came on Mid 136 sid 66 fmi 5 at dealer they told me it’s trailer code can somebody help me with this code
  7. everette72
    everette72 Bobtail Member
    i have the same problem was told by volvo to check brake pressure switch on firewall under steering wheel
