Mid 136 sid 93 fin 4
Discussion in 'Volvo Forum' started by v6killer, Apr 14, 2013.
  1. v6killer
    v6killer Medium Load Member
    448
    122
    Dec 6, 2010
    ChicagoLand
    This only seems to pop up if I hit a huge water puddle or Am driving in a very heavy rainstorm, Sometimes when I start the truck in the rain I get this code also. I know it's the ABS brake system, I tried searching for this code on the Internet very difficult to find what's wrong, I'm think I'm down to a wire shortened to ground but I'm not sure what axle.
    I can drive all day in the snow and rain it will never pop-up but when I hit a huge water puddle, the code will pop up on the dash, and the two lights in question will light up. TCS ABS.
    Any help would be appreciated, I like to fix things before they start to go really bad.
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    9PMV/TCV/Diff Lock Common Shorted to Ground... it is solenoid located in the middle of frame in drives area
    v6killer Thanks this.
  4. v6killer
    448
    122
    Dec 6, 2010
    ChicagoLand
    Thank Pablo
    Is the solenoid bad, or Just the wires that connected to it, I think I found what you're talking about, it sits almost under the fifth wheel, On the crossmember of the frame. I think there is about four plugs
    that connect into it I'm going by memory, I was under truck late fall looking at those wires and question.
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    no, two pin plug
