Mid128,sid27fmi7.pls help
Discussion in 'Volvo Forum' started by Benek, Apr 22, 2018.
  1. Benek
    Benek Light Load Member
    83
    39
    Feb 10, 2016
    Woke up this morning and started a truck this code came active, shut the truck for a few minutes, started again and code is now inactive. What's going on? Can someone please help
  3. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Need a lil more info. Year miles and motor/trans combo.
    Benek Thanks this.
  4. Benek
    83
    39
    Feb 10, 2016
    09,1milion.d13 engine rebuild @650 k miles, automatic transmission
  5. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Was the turbo replaced?
    Benek Thanks this.
  6. Benek
    83
    39
    Feb 10, 2016
  7. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    need to remove actuator and check turbo sweep if it is getting stuck or not, i thought this was a d12 but a d13 a little bit of a different issue. you need ptt to remove turbo as you need to properly calibrate actuator for install after removal.
    Benek Thanks this.
