Might be a stupid question, but....
Discussion in 'Experienced Truckers' Advice' started by sirhwy, Mar 23, 2020.
  1. sirhwy
    sirhwy Medium Load Member
    347
    709
    Sep 1, 2011
    Central Iowa
    Does everyone know how to grease a fifth wheel?
    I talked to someone today, the subject of applying grease to a fifth wheel seemed rather elusive to this gentleman. Even the type of grease.
    I buy a tube of red high temp grease. Most grease will work, I happen to like the red and tacky, or wheel bearing grease.
    Pull off the plastic cap, and pop the metal tab out. Begin tapping the tube, metal end down toward fifth wheel, ensuring the grease makes contact with the fifth wheel. It’s an action of dropping/tapping the tube squarely on the surface of the fifth wheel. A quick pull up will suck grease out of the tube and deposit said grease on the fifth wheel. Repeat until the tube is empty.
    Apply most of the grease on the lower 3/4 of the fifth wheel, when backing under your trailer, line up without touching the fifth wheel to the front of the trailer, drop your air bags, back slightly under the trailer, so the whole fifth wheel is under, then air up your bags. Get out and look to see that everything is of the appropriate height, and gently back under/connect with the king pin. If done correctly, you shouldn’t lose all your grease to the front of the trailer, thus avoiding a mess.
    The other method is to buy a tub of wheel bearing grease at your fav auto parts store, apply the desired amount with a stick, such as a paint stirring stick. Back under the trailer as described above.
    chitaylor, D.Tibbitt, tscottme and 4 others Thank this.
  3. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    i clean the old grease and dirt out of the grooves once a month. then grease it good
    catdog45, jsnell and sirhwy Thank this.
  4. ChevyCam
    ChevyCam Light Load Member
    269
    402
    Mar 4, 2018
    How about greasing the entire truck, how often are you guys doing the brakes, driveline, steering shafts, front end and hood hinges? Curious as a new O/O..
  5. DmitriyKW
    DmitriyKW Bobtail Member
    47
    65
    Feb 10, 2015
    Sacto, CA
    I grease my truck & trailer whenever I feel to it might be after like 4-7k miles, I do change oil every 12-15K miles. So basically once between oil changes for sure, maybe truck twice. It just depends my mood and weather. It's not going to hurt your truck. Most of the time I grease fifth wheel when I do delivery and you need to disconnect.
  6. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    every 25,000
    catdog45 and Hegemeister Thank this.
  7. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    I grease mine whenever I disconnect. I use those little premade pouches, slap two down and hook.
  8. Capacity
    Capacity Road Train Member
    1,499
    3,119
    Jul 28, 2019
    Neenah Wi
    Jack up the front end , wheels of the ground to hit the King Pins good.
  9. AModelCat
    164,691
    Front to back every Saturday is how we did it. Guess what? NOTHING wears out! Even beating up and down bush roads all day long in the dirt and mud. Grease is cheap.
  10. Long FLD
    Long FLD Road Train Member
    12,880
    53,927
    Mar 4, 2015
    Who greases a 5th wheel anymore since the no lube top plates came out?
  11. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    everyone
    catdog45 and Flat Earth Trucker Thank this.
  12. Long FLD
    12,880
    53,927
    Mar 4, 2015
    Guess that extra couple hundred when you spec a truck must be too much for most. Little bit of grease on the jaws and you’re good to go. No boobs of grease falling off the plate on the trailer when you turn.
    Deere hunter, stwik and truckdriver31 Thank this.
