Million Dollar Question
Discussion in 'Peterbilt Forum' started by 386chris, May 11, 2023.
  1. 386chris
    386chris Bobtail Member
    6
    May 11, 2023
    San Fernando Valley
    I’ve been struggling for a while now with this, not sure if all trucks do it but on my 386 with a ISX15, when you turn the ignition to the on position, the truck starts the Systems check, now during the systems check it releases little bursts of air and one significant burst at the end of systems check.
    Does anybody know what valve controls the last burst? I’ve asked the dealer and several mechanics and nobody knows .
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    ABS? Does it do the same thing regardless if your foot is on the brake or not when you turn the key to run position?
    Where is it releasing the little air bursts from?
    tscottme Thanks this.
  4. gentleroger
    gentleroger Road Train Member
    7,898
    21,622
    Jun 1, 2010
    My guess would be the transmission.
  5. 386chris
    6
    May 11, 2023
    San Fernando Valley
    Yes does it regardless and it sounds like it’s coming from driver side air tanks area
  6. 386chris
    6
    May 11, 2023
    San Fernando Valley
    That’s what I thought but I recently had my clutch changed and they said it’s not likely trans is a Eaton 10 speed
  7. gentleroger
    7,898
    21,622
    Jun 1, 2010
    Is it automated?
  8. Goodysnap
    Goodysnap Road Train Member
    3,773
    9,199
    Jul 12, 2017
    Last component in chuff test cycle is traction control valve. D396DA9D-5623-4D3B-885A-D2B03A65F737.png
    RockinChair, Lav-25 and gentleroger Thank this.
