Mirage mx keeps blowing fuse
Discussion in 'CB Radio Forum' started by JForce28, Nov 8, 2025.
  1. JForce28
    JForce28 Medium Load Member
    394
    438
    Oct 18, 2019
    I have a mirage MX 36 HP three radio and I’m in a 2023 international LT I’m a company driver. All the wires were in the truck to set it up. It was just a simple plug and play radio turned on fine but when I go To key up the mic I blow a two amp fuse every time
    I usually use the CB shop on I 80 in PA at the TA in Brookville. Don’t know when I’m gonna get through there again so I want to come on here and ask some suggestions on what I could do.
  3. Ridgeline
    22,724
    123,383
    2 amp fuse?
    start with a 5 amp or 7.5 amp
    Timin770 and JForce28 Thank this.
  4. JForce28
    394
    438
    Oct 18, 2019
    Thank you. I bumped it up to a 5 and everything seems to working good now.
    Timin770 Thanks this.
  5. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    I use a 7.5 in all my export radios.
    Timin770, JForce28 and Diesel Dave Thank this.
  6. JForce28
    394
    438
    Oct 18, 2019
    I was worried about bumping up the fuse if the gauge of the wire couldn’t handle all that juice
  7. Ridgeline
    22,724
    123,383
    Don't, you're consuming 10 to 20 watts while using 18 or 20/22 gauge wire, with a duty cycle less than 20%, so you are very safe.
    JForce28 Thanks this.
