Mirror Mount & Ground Plane Question
Discussion in 'CB Radio Forum' started by Kobo, Sep 28, 2010.
  1. Kobo
    Kobo Bobtail Member
    11
    Western MA
    Greetings one and all.
    As I troll through the forums trying to absorb as much information as I can I have repeatedly come across the issue of how important a good ground plane is.
    For instance, numerous posts advise placing a magnet mount antenna in the center of a vehicles roof, or such, to maximize the ground plane.
    Whicn leads me to wonder how the countless truckers who have to mount their antennas on their side view mirrors compensate for, what I guess is, a lack of ground plane.
    My question comes from a project I am working on.
    Presently I am using a Lil Wil centered on the roof of my full size pickup. However I frequently have to park in a less than desirable neighborhood and I want to mount an antenna, with a quick disconnect, placed centered / off centered toward the drivers side, behind the cab. Hopefully this will be a little more descrete as well as not force me to continully climb up to remove & replace the antenna as I do with the Lil Wil.
    The antenna I plan on using is a Wilson 2000, which I see mounted on many truckers mirrors, & I will build a steel support which will raise most if not all of the antenna above the cab.
    Thank you in advance for any replies
    K
  3. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    FEW antennas will work without a good groundplane Center of your roof is the best place however it does you little good if someone STEALS it at night .......
  4. Big_m
    Big_m Heavy Load Member
    881
    265
    Oct 13, 2009
    Central Maryland
    You could use a Tucker mirror mount with the quick disconnect mounted to the rear of your cab. Or truck bed. Get the Wilson with the longest shaft. And get the coil above the roof of the cab for the best signal out.
