mismatched double pups
Discussion in 'Experienced Truckers' Advice' started by mugurpe, Mar 31, 2014.
  1. mugurpe
    mugurpe Medium Load Member
    395
    274
    May 5, 2013
    Arlington, MA
    How big of a difference would running two different pup trailers as a double make? (assuming the heavy one is up front)for example, a drop frame moving van 28' (19.5 tires) and a liftgated straight floor pup on 22.5s? Is the pintle/drawbar height always the same height? What sort of concerns are there fore the converter dolly?
  3. Oi!
    Oi! Road Train Member
    1,233
    936
    Jun 20, 2011
    Florida
    I've pulled a regular pup in the front with a liftgate straight floor pup in the back and it didn't make a difference. But I'm not sure how drop frame movers are.
  4. lfod14
    lfod14 Road Train Member
    1,178
    689
    Jan 9, 2014
    Your driving that double through Cambridge? LOL. I could only image that one!
  5. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Funny, because last week I have seen 2 stepdecks pulling a standard flatbed pup trailer.
  6. mugurpe
    395
    274
    May 5, 2013
    Arlington, MA
    We'll be running them out to the pike with 2 tractors and joining them for longer trips when we get that setup going. We do HHG and pups are good for getting into all the f'd up side streets in the area. Instead of one 48' the idea is to load two 28' pups. We use our local single axle day cab for the loads and rent a sleeper truck for the long distance part. We have one dropdeck HHG pup already but the sister to it just came up for sale, but I'd rather get a liftgate dockheight pup for versatility. Just wanted to make sure that'll work before I pass on the matching 2nd HHG pup.
  7. Redman30
    Redman30 Light Load Member
    140
    60
    Oct 28, 2013
    Abilene,Tx
    I pull doubles for a Living. You won't have any problem with that setup.Back trailer will just be taller than the front and will cause wind drag but that shouldn't concern you in the city
  8. mugurpe
    395
    274
    May 5, 2013
    Arlington, MA
    the trailer we have now would be the front trailer, it's 13'6" so I'd aim for another 13'6 pup for behind. I won't be hauling them together in the city, more like bring one to downtown Boston, load it, then swap in the other, load it, then join them out near the highway and drive to San Francisco. That's the plan anyway.
  9. MACK E-6
    50,245
    240,555
    As long as the heavier trailer is in the front you'll be fine.
    You want the weight where you can control as much of it as you can.
  10. okiedokie
    okiedokie Road Train Member
    14,165
    113,125
    Jun 13, 2011
    PNWET
    I've pulled numerous combinations/triples,ect. Tanks,Flats,Boxes. Weight is the most important factor. Sometimes width plays a role. Having a 102" wide van in front of 2 other narrow trailers is a pain. Can't see the other trailers till you turn or they wobble. Having the longest trailer as a lead helps handling properties just like weight.
