Missing engine and electrical warning
Discussion in 'Mack Forum' started by john510, May 7, 2020.
  1. john510
    john510 Bobtail Member
    24
    I have a 1995 Mack CH model tractor with an E7 300 Engine in it.
    Lately When I went to start it when the engine is cooled off it will sound like it missing and blowing some smoke. Yes it sound like its missing, after it warms up for 10 -15 minutes it begins to run fine and no smoke but after running for 5-10 minutes an Orange light on my dash comes on saying “Electrical Malfunction” the truck does this after it cools down for about 1 hour. If I start it and shut it down and restart it quickly there is no miss or smoke? What is your opinion on what could this be? I have a feeling it may be a injector but want to make sure?
  3. 062
    062 Road Train Member
    6,329
    33,969
    Oct 20, 2013
    Brettj3876 Thanks this.
  4. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Runs fine after its warm? Lemme do some digging. If it was an injector I'd think it would do it all the time? Crack the injection lines with it running and see what cyl makes the biggest difference, if any. Start from there
    062 Thanks this.
  5. A Keffer Inc.
    A Keffer Inc. Bobtail Member
    27
    7
    Aug 5, 2010
    Moyock, NC
    If you have the cruise control switch OFF and then push SET, this will blink the malfunction light and tell you the code.
    Example 4-2 would blink 4 flashes, pause for a second, then blink 2 flashes.
    Hit the set button again for the next code, if there is only one code it will repeat.
  6. skallagrime
    skallagrime Road Train Member
    3,855
    9,928
    Apr 10, 2012
    Indiana
    If its missing the engine, then how do you get anywhere?
    Im sorry....
    LoSt_AgAiN Thanks this.
  7. Truckwork2461
    Truckwork2461 Bobtail Member
    47
    15
    Feb 10, 2021
    It sounds like an issue with a harness. Possible injector harness or engine harness.
